It is currently Mon Jul 21, 2025 3:28 am
 Post subject: Which radiator fan ?
PostPosted: Wed Feb 16, 2011 4:18 pm
Hi
Just doing a few improvments to the cooling system and am wandering which is the most efficient radiator fan to use.
The multiblade plastic fan or the earlier type metal fan , or anything else.
Thanks in advance
PostPosted: Wed Feb 16, 2011 5:01 pm
Mods rock!
Not exactly sure what you mean by 'efficient' however the 6 blade 'Export' Fans (if you can find them) push the most air but are noisy. The plastic 11 bladers are good, push a reasonable amout of air, about the quietest of the stock fans and don't suck too much HP from the engine. A two bladers sucks the least HP, is noisy but doesn't push much air either.
PostPosted: Wed Feb 16, 2011 6:31 pm
I find the 16 blade metal fans work fine and are quieter than the plastic ones. They don't bend or throw their blades off either. :lol:
PostPosted: Wed Feb 16, 2011 9:41 pm
I used to think all plastic fans were the same but have found they vary in blade chord length. Here is a selection that I seem to have accumulated:
Blades have different chords but length is the same until they rub on the rad cowl:
And a close-up showing how much they vary. Quite a big range! I have no idea of what the difference in airflow or noise there is between them and I never learnt that part of aerodynamic theory when at uni (would have forgotten it now anyway).
Maybe someone can shed light on the sources of different fans and how they perform?
M
PostPosted: Thu Feb 17, 2011 6:45 am
M
The wider chords were probably introduced simply because they would flex a lot less. As the engines got bigger and more powerful, the parasitic drag was less of a concern and the wider ones would move more air.
The reasoning sounds pretty good in my head anyway :roll:
PostPosted: Thu Feb 17, 2011 10:07 am
The white plastic ones were designed to become brittle & disintegrate into the radiator at speed :roll:
PostPosted: Thu Feb 17, 2011 10:15 am
Ive been happy with my 6 blade metal fan. Prob is a bit noisy but I cant hear it over the exhaust.
PostPosted: Thu Feb 17, 2011 10:22 am
Milatsmadmini
i use a 4 blade.
2 2 blades on top of each other, pushes a monster amount of air, very cool, rather loud, but does the job, like hanra said, cant hear it over the zoorst anyways...
