It is currently Mon Jul 28, 2025 11:39 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Tue Mar 15, 2011 10:14 am
Does anyone know why there are two wires in an aerial setup (out of HU).
Where do they go? At least one is the aerial itself, does the other just go to ground?
PostPosted: Tue Mar 15, 2011 10:21 am
This space for rent
The grounded one is for the shield in a coax cable. It should be grounded at both ends.
PostPosted: Tue Mar 15, 2011 6:46 pm
I have my stereo under the rear seat so what i have done is got an old aerial
cut the end off stripped the outer of it and then got a decent gauge earth wire
(cause it is black) and solderd it together covered that with tape and shrink wrap
then left the wire a couple of metres long and wraped it up behind the seat to the rear window and tucked it in to the rear window rubber . Works a treat
