It is currently Fri Jul 25, 2025 1:05 pm
 Post subject: Top arm replacement
PostPosted: Tue Mar 29, 2011 7:07 am
Any tips and tricks ? Replacing top arms
Thanks
PostPosted: Tue Mar 29, 2011 7:36 am
Mods rock!
Fingers that can bend in every which way......
Not difficult but fiddley. You will need to compress the Rubber Donut to take the load off it to get it out, unless the donuts are karput, in which case you might as well change them at the same time.
Oh, and replace at least the knuckle joint cup while your at it.
PostPosted: Tue Mar 29, 2011 8:19 am
Have all new bits for Front end cones hi Lo's top arms any thing that can be replaced ! But was having a ning nong of a time getting the rubber seals to sit nice ! Plus I have no way of compressing the rubber cones
PostPosted: Tue Mar 29, 2011 8:34 am
im pretty sure when I did it, with hi lows you can get away without the compressing tool
PostPosted: Tue Mar 29, 2011 11:31 am
Mods rock!
I usually fit the seal nearest the grease nipple thus;-
until I get the arm and shaft it and bolted up. Then slide the seal back in to place.
I guess it would depend on the Donuts and Hilos you have as to weather you can get them together without a compressor. I haven't ever been able to do it with new donuts without compressing them.
PostPosted: Tue Mar 29, 2011 3:36 pm
Apparently the thrust washers either side of the arm are different thickness which one goes where
PostPosted: Tue Mar 29, 2011 4:09 pm
This space for rent
Thick (stepped) one to the front of the car ;)
Users browsing this forum: No registered users and 72 guests
