It is currently Sun Jul 20, 2025 4:29 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Mar 28, 2011 7:19 am
OK thanks
PostPosted: Mon Mar 28, 2011 9:01 am
Here's how I fitted mine. Earth strap to switch and then another short cable to the original earth mounting point.
PostPosted: Mon Mar 28, 2011 11:20 pm
phillb wrote:
Currently my car has the type of switch that is part of the negative terminal on the battery. The type where you unscrew the knob to turn off power.
Works well. Easy to fit. Easy to use. Extra security if you lock the boot.
Ew. I had one of those on the Porsche
It melted and went open circuit, with the green knob fused in place.
PostPosted: Tue Mar 29, 2011 9:11 am
I've wondered about those... how do they make contact? how much contact area is there? how much current are they rated to?
seems to me like the contact area would be a lot smaller than the size of the battery post, and the cable it's connecting to...
PostPosted: Tue Mar 29, 2011 9:23 am
Em...chaps...could we get back on topic...:roll:
I'm looking for a battery cut off that meets road rally rules if you don't mind :D
Regards,
Mike
"He who dies with the most toys wins."
PostPosted: Tue Mar 29, 2011 9:28 am
ohhh, in our defence, your original post didn't actually say you wanted it for a race car :lol:
Fairy nuff...
Regards,
Mike
PostPosted: Tue Mar 29, 2011 2:21 pm
Beanie to the rescue try one of these
http://www.autosportdirect.com.au/itemdetailspage/14733
A bit pricy but so is am electrical fire box near the battery and the two buttons can go anywhere ...
Or big red key
Cheers beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Tue Mar 29, 2011 5:29 pm
Perhaps not the most aesthetically pleasing, but it it's certainly functional from both inside and outside.
As well as a battery isolator, this unit has a secondary switch built in which cuts the igntion circuit as well.
Curly
PostPosted: Tue Mar 29, 2011 6:25 pm
That's an important point.
Most cars will continue running even if you isolate the battery.
Ignition cutout is essential.
PostPosted: Tue Mar 29, 2011 6:39 pm
I don't think they're ugly...easier to keep track of than a key too :lol:
 Post subject: Battery switch
PostPosted: Tue Mar 29, 2011 7:54 pm
The only sensible position to put a battery cut off switch is closest possible to the Battery source. No point of switching it half way up the car.
"Let us remove your "SHORTS"
 Post subject: Re: Battery switch
PostPosted: Tue Mar 29, 2011 8:43 pm
Mods rock!
I would agree all the way with that. Putting the switch in the boot doubles as a fairly effective disabler too.
PostPosted: Wed Mar 30, 2011 4:46 am
Well I'd disagree a little bit. On a competition vehicle it should be where the regulations require it to be, as is mine in the picture above. Halfway down the car or not, it's about accessibility, and the fire crew knowing where to find it, not having to ferret in the boot on the chances that's where it is. I think it eventually became apparent that the OP is talking about a race car, in which case he should probably be looking at their rules.
 Post subject: Race car rules
PostPosted: Wed Mar 30, 2011 6:10 am
Race car rules are not always written by Auto Electricians. It makes no sense to put a switch any where else but as close as possible to the battery source and switching the NEGATIVE. I can not see it being a safety Item if it is not near the battery. What if the car gets hit and the battery cable going to the switch (most cases switching the positive) gets pinched between two mangled up panels and shorts out, how do you switch that off ? It is actually very dangerous to have live cables between the battery and the switch. It might be ok on rear wheel drive cars with the battery in the front to have a switch in the front (Close to Battery source) as long as it switches the negative. But to be safe on a mini with the battery in the back switch would be more effective close to the battery and not close to a Hit point on the car. I am not trying to contradict any one's opinion I am just quoting from my experience with racing and Electrics. Every one has his own idea.
Users browsing this forum: Majestic-12 [Bot] and 79 guests
