It is currently Sun Jul 27, 2025 10:37 pm
 Post subject: any ideas?
PostPosted: Tue Mar 29, 2011 7:46 am
hi everyone,
just wandering what the experts thought, anyway the temp, spedo and fuel guages dont work in my car, i understand it could be a list of things but there is a wiring issue with the car, so any ideas?
1969 mini k
PostPosted: Tue Mar 29, 2011 7:56 am
temperature and fuel guages are electric- so the wiring could be the cause
the speedo runs by cable... do you mean the lights in it dont work?
Is this a cluby or roundy?
I would check the voltage regulator thing in the back (rectangular grey box with a number of plugs prodruing from it that clips into the back of the speedo cluster.
PostPosted: Tue Mar 29, 2011 8:02 am
hi again,
its a 69 mini k and all the lights in the instrument cluster do work the spedo needle dosent move, the temp needle and fuel needle dosent move and $20 worth of fuel was put in it yesterday and yet the needle didnt move
thanks again. sam
1969 mini k
PostPosted: Tue Mar 29, 2011 8:20 am
Hi sam,
You can test the temp and fuel needles themselves by grounding the wire before the sensor. For the temp sensor, for example, pull it the wire from the sensor (it's just above the alternator in my mini), and push it against something that's grounded (like the engine - provided you can get a clean connection). The temp gauge should shoot straight up to hot. If it doesn't, there's something wrong with the wiring or the gauge itself.
Since it's a few things, and a mix of mechanical (the speedo) and electrical, I'd say you instrument cluster has been disturbed - some of the plugs may have come out. I have a clubby with a different cluster to yours, so hopefully someone else can explain how to check a mini k cluster for you.
Cheers.
PostPosted: Tue Mar 29, 2011 8:27 am
has it suddenly jjust stopped working or hasnt worked since you go it?
I too own clubbies........
As irish Yobbo said grab your fuel sender wires and eath them out, it should move the guage. If it does you will know your sender unit in your tank has kicked it in. If it doesnt move.. I dont know.....
Have you checked your speedo cable isnt broken?
Good luck
PostPosted: Tue Mar 29, 2011 8:41 am
hi all,
thanks guys for all your help, i will try those things and hopefully get them working :roll:
thanks again
sam.
1969 mini k
PostPosted: Fri Apr 01, 2011 8:46 am
Hi Sam,
I also have a 1969 Mini K.
The temp and fuel gauge run off the voltage stabilizer which is located at the back of the speedo.
Check to be sure it is wired correctly.
Users browsing this forum: fuzzy-hair-man and 87 guests
