It is currently Sat Jul 12, 2025 1:01 pm
Post new topic Reply to topic  [ 91 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Sun Apr 10, 2005 9:48 pm
gumby07 wrote:
hey i forgot to ask.. i got my hi lows installed for me so i dont know the spanner sive that i need to adjust them... :( does anyone know? thanks
a big shifter does the trick ;)
I put the rear Konis and HiLos in today but ride height hasnt altered at all and the Hilos are wound right in. Are we supposed to trim a bit off the extension bars to get "lower" than standard ride height? As it is, I can only go up from standard unless I cut a piece out of the extension bars.
Im thinking 12mm? The inside of the bar is machined to take the knuckle only as far as about 50mm and the shaft of the knuckle is about 25mm.....?? Anyone else cut their extension bars?
www.crazybitchracing.com
PostPosted: Sun Apr 10, 2005 10:08 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
you need to drive and let them settle
makka
PostPosted: Mon Apr 11, 2005 5:48 pm
crap don't machine them :shock: you probly find the cone and the Hi lows arn't seated perfectly...Get in the back and jump around a bit but they will settle down soon..you don't want to go over the pits to low anyway :wink:
PostPosted: Mon Apr 11, 2005 5:57 pm
but
but
I lined the new Hilo (at lowest setting) with extension bar up against the original trumpet (on the ground) and they were the same length.
I took a pic so will post that and a pic of how high its sitting right now. Whats to settle? Its the original cones (seemed fine) and I'm pretty sure its all seated correctly in their own little places...
aaaaw you guys don't believe me :cry: No-one has ever trimmed the extension bars....? OR what length is a normal extension bar? I'll measure mine later tonight.
PostPosted: Mon Apr 11, 2005 6:01 pm
You don't need to touch the length of the bar..it's all in the Hi Lo...I would say the Knuckle is not seated in the cup all the way in..it will settle down :wink:
Yer give us a Shot
PostPosted: Mon Apr 11, 2005 6:09 pm
Anyone know any other places in Sydney that sell the extension bar, Karcraft are out of stock and they dont know the progress of there shipment, and i really want them :( :(
PostPosted: Mon Apr 11, 2005 6:10 pm
Right.
This is howhigh its sitting, HiLos wound in as far as they can:
and this is the HiLos lined up agaianst the cone.. same frigging lenght... wound in as far as they go :(
PostPosted: Mon Apr 11, 2005 7:42 pm
Not wound in :idea: you should be able to wind it in till both the bolts are sitting together.
Does not look like a Hi Lo eather...did it say Hi low on it any where..
Did you replace the Knuckels
PostPosted: Mon Apr 11, 2005 7:59 pm
that was WOUND IN as far as the thread goes!
It wont wind IN any further!
I suppose I could get the thread extended so both the nuts sit together, but thats only going to give me another 10mmish, which will probably be ?? 50mm lowering?
I'm going to have to CUT them :roll:
The HiLo part seems perfect, yes they have plenty of adjustment but its all UP until I cut the bars shorter.
Don't worry bout it
*where's my hacksaw?
PostPosted: Mon Apr 11, 2005 8:57 pm
Mrcooms, the rear extension bar is only the rod out of the wet suspension, mini clinic on gibson ave should have them... Or any other mini place might have them as well..
Daniel
Life's a garden.... Dig It!
PostPosted: Mon Apr 11, 2005 11:47 pm
Sweet ill give mini clinic a ring tommorrow to see if they have em, i really wanna get these HiLo's in before the cruise this weekend. Im assuming that the setup is exactly the same one the rover subframe. ill be highly annoyed if its not!!!!!
PostPosted: Tue Apr 12, 2005 2:34 pm
K got my HiLo's today. But far out right after i bought them some guy walks in and starts giving me a serve, ohh what u putting HiLo's on for, ur stupid, keep it original, dont lower it.
I mean comon.
1. its not like im dumping in on the ground full ricer style
2. its not like i cant put the trumpets back in.
Well now the task of putting them in, the biggerst thing im worried about is taking the tank out.
PostPosted: Tue Apr 12, 2005 3:17 pm
I mean comon.
huh? you shouldnt need to take the tank out :roll: oh maybe for a sedan.. definitely not for the van...
PostPosted: Tue Apr 12, 2005 3:25 pm
I don't see why you would have to take the tank out on a sedan either...
everything you need to play with as far as I know is outside the car in the rear subframes :? :?:
Roads need more corners
PostPosted: Tue Apr 12, 2005 4:04 pm
the tanks coming out as well becluse i am putting in new shocks.
