It is currently Sun Jul 20, 2025 8:51 am
 Post subject: 10" wheels fitment
PostPosted: Tue Apr 05, 2011 8:46 am
HI everyone
was looking at changing my 12" wheels for 10" ones.
are there any 10" wheels/rims that will fit over 8.4" solid disc brakes? i am using the standard calipers.
Jason
PostPosted: Tue Apr 05, 2011 9:01 am
The simplest answer to your question is no.
Some companies in Japan developed 10" wheels for 8.4in brakes but they sit 'next' to the wheel hub not 'over' it. The end result is the car is a foot wider than normal.
The simple math is a 10" rim is 9" inside, less the rotor diameter leaves 0.3" clearance (8mm) to get a caliper in. Not going to happen.
PostPosted: Tue Apr 05, 2011 9:33 am
OK so if i want 10" wheels i will have to change the brakes yeh?
8)
PostPosted: Tue Apr 05, 2011 9:39 am
Yep.
You should only need the calipers, rotors and drive flange, so no need for a whole kit or anything.
Or you could just stay with 12" wheels. :lol:
PostPosted: Tue Apr 05, 2011 10:00 am
yeh i think i will stick the the 12's for now :lol:
had a funny feeling that was the case
8)
PostPosted: Tue Apr 05, 2011 11:05 am
Or just machine down the rotors to 7.5" and get some alloy 4 pot calipers.
Nicer brakes and 10" wheels...win win!
PostPosted: Tue Apr 05, 2011 11:47 am
Nicer looking: not necessarily better for performance.
PostPosted: Tue Apr 05, 2011 11:58 am
I changed it from better to nicer when I was writing!
