It is currently Tue Jul 22, 2025 6:15 pm
PostPosted: Mon Apr 11, 2005 7:47 pm
Guys, as title says the ignition light is staying on whilst driving...... is it a wiring problem, or something more sinister (Alternator :shock: )
I got nuthin......................
PostPosted: Mon Apr 11, 2005 7:51 pm
My money is on the alternator, (or the V regulator if it's the early 15AC with separate reg so beloved by S owners...)
Could just be slip ring brushes- if so it's a cheap easy fix on `most' Lucas alternators. :wink:
PostPosted: Mon Apr 11, 2005 8:06 pm
Doc.... whereabouts is the V Regulator in the engine :oops:
PostPosted: Mon Apr 11, 2005 8:32 pm
O dear it's Spreading
PostPosted: Mon Apr 11, 2005 8:52 pm
I`d just check that the fan belt is actually still on there first,,,
If it is,,,then look at the wiring or altinator for faults
PostPosted: Mon Apr 11, 2005 9:08 pm
With a 15AC alternator it's on the RH inner guard, a square box about fag packet size.
On all the ones since (ie Clubbie ones) it's inside the alternator. More reliable.
:idea: Get a spare (good) alternator- it's a handy thing to have if you drive a Mini.. :lol:
PostPosted: Mon Apr 11, 2005 9:20 pm
Ha haaaaa....take that you hack...
PostPosted: Tue Apr 12, 2005 12:11 am
NAV-MAN
Very good advice. Been stuck on the side of the road with a seized alternator which snapped the belt. all in the middle of nowhere well ok kempsey that added an extra 5hrs to my 12hr trip
PostPosted: Tue Apr 12, 2005 4:35 pm
Problem when checked this arvo was intermittent..... changed the V Regulator and the problem seems to have disappeared :? ........ hopefully that was the cure :?
Users browsing this forum: No registered users and 72 guests
