It is currently Mon Jul 28, 2025 7:50 am
 Post subject: What is it
PostPosted: Wed Apr 06, 2011 7:00 pm
Ok experts try and identify this mini for me what is it
I think it may be a 69 morris mini matic
From an old NSW Certificate of registration that was found in the vehicle
and is hard to read VIN YA2S51092 ENG NO 9YATAH26891S
No VIN or data plate or any evidence of rivet holes, there is some numbers stamped into the bonnet channel hard to read
it was fitted with a 1098 manual engine, hydro suspension, auto subframe with little steel blocks for the engine mount, auto acc pedal.
last registered in 1995
Thanks Les
Alpine Mountains full of Mini's and Moke's.
PostPosted: Wed Apr 06, 2011 7:15 pm
Hi Les, I did a search, and came up with this from Watto. Being a '69, they wouldn't have fitted an ID plate to it
watto wrote:
YMA2S5 is certainly Mk2 (or MkII) Mini-Matic (don't forget the hyphen :lol: ) Released in September 1969.
Although mechanically the same as the Mk1 (YMA2S4) it had the same interior trim, including the three-gauge dash, as the Mini K, but was still only 998cc - I think the compression was a little higher or something as well.
It is a rare beastie, so if anyone has one I can photograph for a feature in TME, please let me know.
Watto. :shock:
PostPosted: Wed Apr 06, 2011 7:16 pm
Online
YA2S5 is a MiniMatic (1969 on).
I've had 2 with this body prefix.
The original 998 auto motors in these were all 99H/119/H prefix (imported from UK).
Simon K, there is no `M' in the prefixes, that was dropped in 1969.
 Post subject: mini matic
PostPosted: Wed Apr 06, 2011 7:54 pm
Thanks guys
Is there any letters or numbers that should be stamped into the top radiator shroud
the only numbers I have found are stamped into the bonnet gutter drain
they do not relate to the numbers on certificate of registration
Thanks
Les
 Post subject: Re: mini matic
PostPosted: Wed Apr 06, 2011 8:08 pm
Online
ALPINE MOKE wrote:
Thanks guys
Thanks
Les
On a 69 Matic your radiator shroud should have the number, YA2S51092 stamped in.
This is the car number location used for registration on a 1969 or later.
If numbers not there, check for dodgy welding where the shroud meets the inner guard- it may have been changed for `some reason'.
The numbers stamped in the gutter drain are the body number, it's about 500 different.
 Post subject: body numbers
PostPosted: Sun Apr 10, 2011 2:11 pm
Ok thanks all for the infomation.
I found the numbers under a lot of paint on the top part of the radiator shroud.
It is a late model Morris Mini Matic 1969
Thanks
Users browsing this forum: drmini in aust and 75 guests
