It is currently Sat Aug 02, 2025 8:03 am
PostPosted: Tue Apr 19, 2011 7:04 pm
heard a few different ways.
best one so far is rev it to about 2,000 or 2,500 for round 10 to 20mins or so up & down between that range.
i also bought some cam running in oil with a zinc additive .
should i use normal engine oil? the engine has done about 20,000km.
i was thinking best to run it in N/A before i bolt the blower on.
opinions?
PostPosted: Tue Apr 19, 2011 7:26 pm
what did GR say to do?
have you bought new followers as per his recommendation?
PostPosted: Tue Apr 19, 2011 7:30 pm
Current thinking is stick it in, start motor & then go DRIVE it for 20 mins or so. Up a hill or two.
Revving it in neutral for 20mins with no load is just a recipe for glazed bores and then poor ring sealing. :wink:
When GR runs them in on his engine dyno, he puts part load on it for 15-20 mins. Hard to do this in yer garage....
PostPosted: Tue Apr 19, 2011 7:40 pm
yes isky ones.
PostPosted: Tue Apr 19, 2011 7:43 pm
my engine has done 20,000km so rings bed in a long time ago.
i could just put it in & go driving but what about fuel, my carby was set up for a 266 cam on the dyno.
do you really need load up the car? i assumed there is no load on the cam. just the drive train pistons etc.
PostPosted: Tue Apr 19, 2011 7:44 pm
Jetting it has will be fine for the running in...
Rejet it later if you need to.
No if the rings etc are bedded in already, then 10-15 mins @2000rpm is fine.
I assumed the engine was a rebuild.
PostPosted: Tue Apr 19, 2011 7:46 pm
Mods rock!
opinions?
Your Cam supplier should have given you this information. Seek their advice.
PostPosted: Tue Apr 19, 2011 7:58 pm
do many of you use oil with a zinc additive??
PostPosted: Tue Apr 19, 2011 8:12 pm
I use SG oils (KMX 20W/50 and Castrol Edge Sport 25W/50).
SG and lower (SE, SF) oils still have ZDDP, it's the SH and later where they lowered or eliminated it.
PostPosted: Tue Apr 19, 2011 8:15 pm
ok i always use Castrol Edge Sport 25W/50, i have a special cam zinc oil additive also to add to the oil when first running in the cam.
PostPosted: Tue Apr 19, 2011 8:23 pm
Just a question nick (ok make that 2 ) .... which run in lube did you get... and did the lable say to pour it in the oil or to lather it on the lobes :?:
PostPosted: Tue Apr 19, 2011 8:32 pm
moly for the cam.
the oil is a pour in type to be mixed with the engine oil when you run the cam in, only use the oil for 100km & then you need to drop the oil & filter & put fresh oil in.
edit let me find the bottle.
PostPosted: Tue Apr 19, 2011 9:12 pm
Moly Grease or molybond?
PostPosted: Tue Apr 19, 2011 9:20 pm
Not sure my mechanic is doing the cam.
