It is currently Mon Aug 04, 2025 11:22 am
PostPosted: Thu Apr 21, 2011 12:38 pm
I've just fitted my pedal box and new brake and clutch masters and...my pedals aren't level.
The brake pedal sits quite high and the clutch quite low....have I done something wrong or is this normal?
Regards,
Mike
"He who dies with the most toys wins."
PostPosted: Thu Apr 21, 2011 12:46 pm
Its like that in most cars isnt it, for when you slam your foot on the brake. That way your hitting the brake and brake alone..
So... I'm Seifer
PostPosted: Thu Apr 21, 2011 1:10 pm
Not sure bout that well not in any of the minis I've driven even the utes at work are fairly level.
Mts ... How low is low? Are we talking a couple of cm or a few inches. Have any pics will help someone in the know let u know. :D
PostPosted: Thu Apr 21, 2011 1:44 pm
The pedals should sit so that a fully depressed brake is equal in height with the accelerator, right?
At least, mine sits that way, makes double clutching easier ;)
You're so square
Baby I don't care
PostPosted: Thu Apr 21, 2011 1:48 pm
You haven't used one rover pedal and one aussie pedal have you?
There's a height difference of about an inch and a half.
PostPosted: Thu Apr 21, 2011 2:00 pm
Brake pedals on disc braked cars do sit higher than drum braked cars. The disc brake setup uses a booster, which increases the travel, and the pistons in the calipers need more volume of fluid to move which also increases the travel. This is compensated by the pedal sitting higher initially, otherwise it might have to travel through the floor.
On the good side, when you are braking hard and heel-toeing, it will make your foot sit at about the right height to blip the throttle. I find that my drum car pedal sits a bit low for that now it has the discs fitted.
michael
 Post subject: pedals
PostPosted: Thu Apr 21, 2011 2:44 pm
There is something seriously strange going on! Photo's to follow.
Regards,
Mike
PostPosted: Thu Apr 21, 2011 4:41 pm
Are the Master Cylinders standard or after market.
I have found the piston rods are too short on the chinese / after market ones.
I usually extend the clutch one by 1/4 inch to fix the problem you talk about
Lengthing the push rod lifts the pedal upwards
Kiwiinwgtn
PostPosted: Thu Apr 21, 2011 6:17 pm
Mods rock!
In the later cars (~75 on) they do sit at different heights. There are shims that are fitted (usually) under the clutch master cylinder and by doing so lowers the pedal (closer to the floor). God only knows why these are factory fitted, I fling them, but even with the shim removed, the clutch pedal is still lower than the brake.
PostPosted: Thu Apr 21, 2011 6:56 pm
wouldn't worry too much. My clutch as always been lower then the brake. In 7 of my 8 cars I've had all brake pedals have sat higher and not same level. I find this better as others have meantioned as when braking hard, and can tap the accelerator with ease
Users browsing this forum: fuzzy-hair-man and 104 guests
