It is currently Thu Aug 14, 2025 12:49 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 235, 236, 237, 238, 239, 240, 241 ... 568  Next
PostPosted: Sun Apr 24, 2011 11:32 pm
Work on the MGB moves along. Replaced the castle rail on the LH side and related membrane and floor/sill repair with new steel. After sound deadening removed, floors acid treated, etch primer and seam seal. Also etch primed and seam sealed the engine bay after acid wash. Next fresh paint in the engine bay and reassembly can follow.
PostPosted: Mon Apr 25, 2011 1:44 pm
Fixed my electrical fault from yesterday,
Cleaned up the chome to a nice shine,
Took the little bugger for a spin...
Might take him out again later, beautiful Melbourne Day!
1970 Cooper'd K
by "Cooper Works"
PostPosted: Mon Apr 25, 2011 2:24 pm
Not is very mini friendly day on Sydney, hissing down with rain.
Doing some more work on the project's engine and gearbox. If it stops raining I can paint the engine
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Apr 25, 2011 4:12 pm
Over the last few days..
Drove it to Wagga for the moke muster, ran fine, pulled strongly, didn't overheat and only blew a tire because a 4WD threw some crap at the side of my car which tore through the tyre..
Got shunned by 9/10 mokers there for bringing a mini because "Mokes aren't mini's"
Was requested to leave my car out of the parade by the fuzz, courtesy of a certain member on ausmini.
Drove it home again, hitch free this time. Until my spare tire exploded spectacularly 50km out of sydney. Quickly (much quicker than last time) replaced it with the other spare and continued on home.
A prediction for tomorrow's 'what did I do on my mini':
Unpacked all the camping gear, thought about washing the dirt off it from Wagga, but didn't.
You're so square
Baby I don't care
PostPosted: Mon Apr 25, 2011 6:36 pm
Masked up the engine so it is ready to paint tommorrow.
Pulled the steering rack apart. Cam gears type, all nice and tight.
It has been reco-ed in the past but due to both boots being torn it had no oil inside.
Now need a repair kit and I can fix. :)
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon Apr 25, 2011 7:16 pm
this is the sway bar i posted earlier.. i had a go at assembling the ends.. i think it's right, now to figure out where it goes :lol:
 Post subject: More work done on MGB
PostPosted: Tue Apr 26, 2011 8:42 am
Want to move this B before flying to Australia.
Engine bay painted today. Ready for new bits to be bolted on!
PostPosted: Tue Apr 26, 2011 4:02 pm
Just finished etch priming the engine and a few other parts
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Apr 26, 2011 4:09 pm
Pushed the Cooper S forwards and backwards a few times while cleaning the shed.
PostPosted: Tue Apr 26, 2011 9:06 pm
My efforts today.
primed the engine assembly, a few ancillary parts and steering rack.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Apr 27, 2011 3:38 pm
replaced the conical washer & hub nut on passenger side
PostPosted: Wed Apr 27, 2011 7:32 pm
Took the covers of the Cooper S so I can start to prepare for the vic mini car show in May
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Thu Apr 28, 2011 9:55 pm
Fitted a new idler gear bearing into the primary gear cover and bolted the cover onto the engine
Lapped the flywheel onto the crankshaft and fitted the flywheel
Tried to torque up the flywheel nut and found the ring gear is slipping on the flywheel
Bugger! :shock:
Now I need to find someone to "weld"? The ring gear
OR maybe fit a new ring gear?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Thu Apr 28, 2011 10:00 pm
Unless you have an aftermarket steel flywheel, DO NOT weld the ring gear on! :shock:
Get a new ring gear and shrink fit it on as original.
Stock Mini flywheels are all grey cast iron- arc welding the ring gear to it is an invitation to crack.
Minimatic ring gears were welded on- but their torque converter housing is steel, not iron.
PostPosted: Thu Apr 28, 2011 10:14 pm
Thanks Doc, I was going to seek mini persons assistance tomorrow and would hope they express the same warning :?
Just annoying when I think I will have 10 steps forward in my engine rebuild I get hit in the face with another issue
Maybe it's revenge of the clubbie :shock:
1969 Cooper "S"
1967 Mini Deluxe
Users browsing this forum: Bing [Bot] and 294 guests
