tracytracey wrote:
Thanks drmini, where can I get a top hose with a takeoff, I need to put in a new radiator as the current one has the heater hose coming up the front and I can't shut the bonnet properly. It is a 1275LS engine in a traveller shell if that makes a difference.
You would probably need to make something up with a tee fitting. Or add another hose connection to the top tank (a radiator repair shop can do this). IMO a waste of time in Tassie as it's cool down there.
C'mon Kev, have you got ice in your veins?
I lived through a couple of Tassie winters and I put a heater in for the first time so that the inside of the car was WARM for a change
michael
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
