It is currently Fri Jul 18, 2025 4:01 pm
PostPosted: Tue Apr 26, 2011 12:42 pm
Has anyone successfully used one on an Australian Mini? Which kit did you buy?
I'm going to get another mini soon as a project to tear down and fix up with a later model motor.
It seems like an easy option to buy a complete honda kit from O/S and just source a motor locally but it doesn't look like anyone has done it.
Is there a reason for this?
Dan
PostPosted: Tue Apr 26, 2011 12:52 pm
because it's not that easy :lol:
I think there are problems with the steering rack fouling on the gearbox for RHD cars for those standard kits.
PostPosted: Tue Apr 26, 2011 1:05 pm
Is that the only reason?
I thought I saw a kit that was compatible with both lhd and rhd models.
Of course I cant find it now. : /
PostPosted: Tue Apr 26, 2011 1:21 pm
Found it.
Here is the kit, they mention that you need another kit to fit it to a RHD mini. The floor/firewall needs to be modified. That might be why its not done often.
http://superfastminis.com/MTB2.html
http://superfastminis.com/RHD%20CONVERSION%20KIT.htm
PostPosted: Tue Apr 26, 2011 2:11 pm
I read on the moke forum the kits are no good because they increase the track width of the car by too much?
May not be any truth in it, but worth looking into before you sink a few thousand into the subby
You're so square
Baby I don't care
PostPosted: Tue Apr 26, 2011 3:20 pm
From the pictures on there website looks the same as mine with 13x7's on.
Cheers Pete
http://superfastminis.com/A_CHUNG.htm
http://superfastminis.com/TWEST.htm
PostPosted: Tue Apr 26, 2011 8:24 pm
i've been looking into doing the same thing and have been told by a few people that the allspeed engineering one doesn't increase the track width, also says that on their site, there are slight body mods needed but they have a PDF on the site for you to have a read if you wanna check it out...
according to a source, it's been engineer passed here in vic, the guy who owns the car had modified some of the support parts but it was his decision, wasn't told to do so by the engineer.. trying to find who it was so i can have a chat with them myself.. :wink:
if you find anything out, let me know if you can.
Cheers, Sean.
So what's the last thing you remember...
I'm pretty sure you were..
WRONG ANSWER!!!
PostPosted: Tue Apr 26, 2011 10:34 pm
That allspeed one looks good. No increase in track.
http://www.allspeedengineering.com/subframes.htm
They recommend a flip front if using a morris but Ive got no issue with getting a clubman.
It comes at nearly $3k not including postage.
PostPosted: Sat May 14, 2011 11:09 am
Die Die Die!!
the guys at mini tec generally offer an international discount to try and offset that its being shipped to australia
