It is currently Sat Aug 23, 2025 7:30 pm
PostPosted: Mon May 16, 2011 10:12 pm
Hey all. The clubbys got a fuel leak. And I fixed it once by replacing the hose from the pump to the under body lines.
Now its developed a leak again but doesnt look like the hose this time. When I noticed it I could see petrol around the top of the pump near the intake side, So i imagined the hose leaking again. BUT tried to confirm it tonite and after running for a few mins a small dark patch forms from the pressed part of the housing. ie, the two halves of the pumps diaphragm area.
Is this a common this to leak, through this pressed joint?
Also, can a mechy fuel pump be replaced with engine in? just remove intake manifold?
Cheers for any advice :)
-Motor mechanic - Proud owner of a '76 Clubman S and a Ford ef xr6 manual :P
PostPosted: Mon May 16, 2011 10:25 pm
Yes it is possible to replace the pump in the car. Should only need to remove the carby/s to gain access.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon May 16, 2011 10:42 pm
cheers michaelb,
Probly should just replace it anyway ay.
PostPosted: Mon May 16, 2011 10:47 pm
I'm not sure if you can buy repair kits any more as last time I tried I had to buy a new pump from karcraft as they had not kits
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon May 16, 2011 10:59 pm
yea minisport only have whole units. Maybe ill just fit a new one, and see how goes. :)
 Post subject: Fuel pump leak.
PostPosted: Tue May 17, 2011 5:47 am
Best solution is to remove pump, fit a blanking plate to cover the hole in the block and fit an electric Pump at the rear of car. Remember that to do this you will need to run a 'Fused' Ignition positive feed to the rear of the car to supply the pump. It is also always better to have the Fuel pump away from Extractors if you have them fitted.
"Let us remove your "SHORTS"
PostPosted: Tue May 17, 2011 6:22 am
Mods rock!
It is a fairly common problem. Sometimes, after removing the pump and placing it in some timber block, you can tap the crimps in a bit tighter. I usually run a bead of Araldite around them too.
PostPosted: Tue May 17, 2011 8:11 pm
UPDATE
its definitely the housing, so im gonna try another mechy pump for now. maybe ill change to electric when I get the weber sorted out and ready to put on lol
Users browsing this forum: AWOODY and 299 guests
