It is currently Tue Jul 15, 2025 4:10 pm
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Jun 26, 2011 2:13 pm
Mods rock!
Just be careful drilling the sump as most twist drill bits will 'bite' and suddenly pull in. Not far behind the sump plug is the pick up strainer and the pick up pipe itself. You don't want to damage either of these.
I have usually found the Helicoil taps will wind in without drilling.
PostPosted: Sun Jun 26, 2011 2:27 pm
Yeah, thats why I'd rather get someone experienced to do it, I was peering down the sump plug and could see the pickup strainer and was thinking the same thing.
PostPosted: Sun Jun 26, 2011 2:32 pm
:shock:
Be EXTREMELY careful if you're going to do that. I have found out the hard way that EVEN ON ALUMINIUM you can very easily break helicoil taps if you don't pre-drill..... If you MUST do it without pre-drilling, pay attention to the way it feels.. if its fighting you at all STOP before you break the tap.
Usually the exisiting hole is a smaller diameter than the minor diameter of the thread for the helicoil.... meaning you're trying to force the hole bigger if you do it with out pre-drilling.. instead of cutting the hole bigger.... taps are not designed to work this way.
PostPosted: Sun Jun 26, 2011 6:07 pm
Mods rock!
Phat Kat wrote:
:shock:
Any tap will break if your not careful. Done a few this way without problem. Might be the crap taps you use......hang on......
PostPosted: Sun Jun 26, 2011 6:35 pm
GT mowog wrote:
Phat Kat wrote:
:shock:
I'm sure you have, I'm just saying I wouldn't really encourage anyone else to do it. I've used genuine Helicoil and Recoil mostly, but from time to time other brands.
All I'm saying is, for someone who's not done it before, or has limited experience, I'd rather see them learn to do it the right way before they try doing it the "Good enough for the bush" way... they're more likely to have sucess.
edit: as for the quality of them, they are pretty damn good... besides,,, its not like you have a choice, you HAVE to use the Taps they give you in the kit
PostPosted: Sun Jun 26, 2011 7:44 pm
Mine has been helicoiled in the past. Try as I might, i cannot get a proper seal with the washer. I think this is because the helicoil is not square to the mating surface.
I think this will always be the danger with helicoiling, especially using a hand drill and in situ -i.e. that the hole is not square to the mating surface of the washer.
michael
PostPosted: Sun Jun 26, 2011 8:05 pm
Mick,
This is exactly why 4myego went the way he did. It works a treat.
It is next to impossible to keep the drill and the helicoil tap dead square to the outer face when doing it in situ.
PostPosted: Sun Jun 26, 2011 8:42 pm
Mods rock!
Mick,
Gee guy's you'd have to be a fair way out for that! The threads on the sump plug and the helicoil too are not what I'd call 'precision' - by any stretch! There is enough clearance between them to pull it up square - unless you were a long way out!
I have seen helicoiled ones leak, yeah, but only because the helicoil wasn't wound in far enough and that last bit of it stops the washer seating.
PostPosted: Sun Jun 26, 2011 9:00 pm
If the copper washer doesn't seat flat, it will leak. Been there, had one someone else did. It's a 5/8 UNC thread and yes, it is a pretty close fit.
You just try and do it square up under there, in the car...on stands.:lol:
Solution on this one (before we swapped cases) was to wipe Loctite on the outer few threads before screwing it in. PITA but it worked.
PostPosted: Sun Jun 26, 2011 9:04 pm
Mods rock!
Yeah, of couse it will (leak)! if it won't pull up square.
I have done quite a few, in the car. Not the nicest of jobs to do, but take a bit of time and presto :D
PostPosted: Sun Jun 26, 2011 9:35 pm
I just hate the idea of doing them insitue..... gah :P
Helicoils are fine. But only as good as the person who put them in. Take your time do it right and you won't have a problem.
That said, I'm rather taken with 4myego's idea. Its very similar to a Time-Sert.. infact I wonder if you can get Time-Serts that size?
PostPosted: Mon Jun 27, 2011 9:09 pm
I think helicoils are mainly desidned to work in blind holes and not holes that
go through metal or alloy like a sump. on my moke it's helicoil was becoming tighter and tighter to get the sump plug in or out and I had a good look one day and the helicoil
had wound itself into the sump by 5-10mm and was only gripping the alloy by a couple of turns and some of these where broken, I managed to dig it all out then re threaded the hole and had a friend make up a new sump plug in a slighty bigger diameter, I retapped the sump in the car but was about 0.0005° out of square so has a slight oil leak
(just like the new then :wink: )
What size helicoil do you guys use? I did look at using another but I think the guy said I'd need to drill the sump out quite a bit bigger or maybe that was the only sizr they had
PostPosted: Mon Jun 27, 2011 9:41 pm
BTW it was not done by me, if it was it would be square dammit :lol:
PostPosted: Mon Jun 27, 2011 9:55 pm
Me too. The good old railways learnt me to chisel & file things flat and drill holes square....
:mrgreen:
PostPosted: Mon Jun 27, 2011 10:09 pm
Blind holes are actually a little bit more difficult because you need to get the tap all the way mostly to the end of the hole, and get the insert's removable tang out. If you don't get the finishing tap far enough in, the insert will be pushed in to a narrower diameter as you install it into the lower part of the hole, and give you problems when you try to tighten a bolt home..
If your thread insert moves in use, use a few drops of stud lock as you put the helicoil in. Wash the area with acetone or Loctite's own proprietary surface cleaner before doing so.
Much easier with small (5/16th, 3/8th, 1/4) sizes however.
