It is currently Mon Jul 21, 2025 3:22 am
PostPosted: Mon Jul 18, 2011 9:34 am
guys take a look at his battery cable in his build thread, it explains a lot! :)
PostPosted: Mon Jul 18, 2011 12:50 pm
I also have checked out the cable from the Soliniod and the starter.... It wasnt the best either. So I have fitted a new one! Fingers crossed for tonight! Running the new Battery cable front to back
PostPosted: Mon Jul 18, 2011 2:34 pm
where should the engine be earthed to? and is there a test to ensure that it is getting a full earth? ie using a multimeter?
PostPosted: Mon Jul 18, 2011 3:08 pm
Through the earth strap on the clutch cover to the inner guard.
Clean the threads on the captive nut on the inner guard with a tap. Same with the clutch cover bolt if you can. Sand with a little sandpaper the earth strap contacts until they are shiny. Do the same with the battery connections in the boot.
You test continuity to ground with a multimeter set to Ohms. Short the multimeter leads first and measure the resistance in the leads. Then test from engine to body (at any point on the engine and body will do). Subtract the shorted leads measurement from the new one, and that is the true value of resistance.
It should be basically zero, but you will usually measure 0.1 Ohms or so and that will be fine.
However, if there is any damage or frayed ends on the cables like you have seen, then replace them outright.
PostPosted: Mon Jul 18, 2011 9:05 pm
Another trick to try is to add some addtional earths.
A good pair (not Kmart) jumber cables are ideal.
Just clip them on to the engine and the body.
Bare metal to bare metal is best
Also are use using an up graded battery. say 400 amp hours (new technolgy) then use say a 40 year old battery cable rated for 200 amp per hour the product is heat as the energy has to go some where
So how hot is hot..
Kiwiinwgtn
PostPosted: Mon Jul 18, 2011 9:41 pm
ok thanks guys,
Ran the new tractor size battery cable ( dont laugh) and managed to get it through the body, around the subframe and mounted it no dramas.
Now, I checked no continuity between the body and the cable :D so as soon as I pressed the starter button at the solinoid there was continunity..
I then disconnected the battery cable and checked the continunity between the solinoid. Earthing.....
disconnected the solinoid cable to starter motor,
and now the pin that you bolt the cable to, has continuity to the body... :shock: so its earthing the cable out at the starter motor..... would this cause my issues? Or is this perfectly normal??
PostPosted: Mon Jul 18, 2011 10:31 pm
Just be careful here, starter motors are very low resistance, they are nearly a short when measured on a multimeter. It will seem like its shorted when it is not necessarily so. That's how they get the current through that they do. Ohms law : Volts/Ohms = Current.
Even if a battery is rated for 400 Amperes instantaneously, it doesn't mean it will pump that through the starter motor. It is capable of 400 Amps which is good, but it will only use what the starter motor needs. Once again, it is down to the total resistance. This is the internal resistance of the battery + the cable resistance + the starter resistance. Twelve volts divided by all this will give you the total current through the starter. It will only use what the starter motor allows.
If after all this, the starter turns over slowly, and there is no voltage drop across the solenoid, then the starter motor will need to be looked at by an auto spark.
PostPosted: Mon Jul 18, 2011 11:05 pm
Thats the one thing about electricity that took ages to fully understand, what your trying to power is the determining factor in how many amps are in the circuit.
Simplify and add lightness
PostPosted: Tue Jul 19, 2011 6:11 pm
Mini RUNS!!!!!! It was a faulty starter!!! YAY!!
PostPosted: Tue Jul 19, 2011 10:50 pm
:lol: :lol: :lol:
simon k wrote:
was wondering that in regards to your little fire...
starter motor drawing too much current = try another one
told ya so :P
PostPosted: Wed Jul 20, 2011 4:47 pm
Glad to see you sorted it.
I had an almost identical problem and after trying new solenoid, new battery (I thought the battery was stuffed because it kept going flat) it turned out to be the starter motor.
Sorry I didn't see this thread a couple of days ago or I could have actually had some constructive input.
Watto.
Users browsing this forum: Bing [Bot] and 92 guests
