It is currently Sun Jul 20, 2025 12:51 pm
PostPosted: Fri Jul 29, 2011 6:29 pm
On the van i have a oil pressure guage but the oil light on the binnacle is not connected. I was wanting to connect up the oil light just to have it working, but found very little clearance between the existing oil fitting on the block and the vacuum advance to be able to fit the appropriate sensor adaptor. Am i making sense? So with having a oil pressure gauge, is an operating oil light on the speedo binnacle really neccessary and of any advantage?
PostPosted: Fri Jul 29, 2011 6:42 pm
A light is a big advantage. It draws attention to the gauge. If the pressure dips in a corner the light will ******, while you mightn't notice the gauge because you are concentrating on the corner the flash of light will catch your attention.
What is wrong with the stupid auto censor? I said F L I C K E R. :roll:
PostPosted: Fri Jul 29, 2011 6:50 pm
you mention pressure and light. i thought, for no educated reason, that the light would only illuminate if the oil level is low. whats the pressure gauge going to react to low oil level?
PostPosted: Fri Jul 29, 2011 6:51 pm
:lol: wondered what you were trying to say
PostPosted: Fri Jul 29, 2011 7:41 pm
If the oil level is too low, the pressure gauge reading will drop on RH bends (like roundabouts taken with verve...) :P
There goes your big end bearings if it happens repeatedly... (nope, I'm not joking).
PostPosted: Fri Jul 29, 2011 8:11 pm
oh, i see. Spoken from experience doc?
PostPosted: Fri Jul 29, 2011 8:15 pm
Experience of rebuilding low mileage 1275 (A and A+) engines where their owners did this... :lol:
Both cranks had about .005-.007" ovality on their crankpins. :shock:
Mains were fine.
PostPosted: Fri Jul 29, 2011 8:59 pm
so an operating oil light would be wise?
PostPosted: Fri Jul 29, 2011 9:01 pm
The problem with standard oil light switches is they only come on at stupid low pressure, like 8 psi or something.
You can get 22psi ones if you look around.
I just use a gauge, but I watch it. :wink:
PostPosted: Fri Jul 29, 2011 9:03 pm
I used to get the ones that came on at about 22psi. It lets you know before you have a problem.
PostPosted: Fri Jul 29, 2011 9:21 pm
Just gun a "T" piece out of the block and have a light and a gauge.
PostPosted: Fri Jul 29, 2011 9:40 pm
That's what I use - works well!
http://minisport.com.au/prod838.htm
Justin
PostPosted: Fri Jul 29, 2011 11:03 pm
I was under the impression the Vac adavnce should be at 2-3 O'clock, I would think either your dizzy is ass about or you have a mighty big T piece?
PostPosted: Sat Jul 30, 2011 7:54 am
unfortunatley most people think that the oil light is just there to tell you that you need to put more oil in :(
PostPosted: Sat Jul 30, 2011 8:44 am
Thats the situation. The existing adaptor will be replaced with another but as you can see there is very little room. Is the dissy out? jubblies i think that adaptor, once the fittings are on would hit the vac advance. T piece could be the go, kenno.
Users browsing this forum: 1071 S and 81 guests
