Mick wrote:
TUCK3r wrote:
just checked then and yes same on both sides of solenoid
Its not the solenoid.
It's a problem with the battery, the battery cable(including connections) or the starter motor.
Measure the battery voltage at the battery terminal while cranking the engine . If it is 3.4 volts there as well, then it is just a flat or ruined battery.
12 volts when the battery is charged indicates a problem with the battery.
It may also be the starter motor, but you can prove the starter by simply swapping the battery with a known good unit. This will also prove the battery is at fault.
I agree with all the points here, and have a few to add. If you think about it, the starter solenoid completes the circuit and allows the current to run from the battery through the starter and back to the battery again. If anything is disconnected along the line, it won't work.
So after checking the battery terminals and clamps, I'd also trace the line running to the starter from the solenoid, and also check your engine earth strap.
