It is currently Sun Jul 20, 2025 4:46 pm
PostPosted: Tue Aug 23, 2011 3:51 pm
Hi guys, I got my self a speedo i was told was out of a mini morris but am now being told that its from a moke, im curious to find out if it is going to work in my mini or will i have to source another one? my mini is about to go in for its road worthy check so that i can register it, any one got any ideas? the only numbers i can find on the back is on a sticker which are "119" or "611" depending on which way you look at it.
Thanks again guys for all your help :)
Regards Kermit (TadPole)
PostPosted: Tue Aug 23, 2011 4:39 pm
do you mean is the speedo going to simply work, as in operate or work and be accurate in its reading once on your car?
PostPosted: Tue Aug 23, 2011 4:48 pm
Since he's taking it in for its roadworthy, it will need to be fairly accurate. If memory serves, your speedo is allowed to read up to 10% above the actual speed, and it cannot read any less than the actual speed. But don't quote me on those figures.
PostPosted: Tue Aug 23, 2011 5:10 pm
what he would like to know is will the speedo read right.
if its a moke seedo in a mini with 10's and we belive a 3.44 final drive, will it be ok ? how far out would it be and is there a list of what seepdo parts numbers belong to what ?
PostPosted: Tue Aug 23, 2011 5:13 pm
sorry, yeah im trying to work out if it is going to be reasonably accurate so that i can use it on the road with out having to worry about getting fined or similar.
PostPosted: Tue Aug 23, 2011 5:33 pm
If youve got a gps you could go for a drive and see how accurate it is.
Simplify and add lightness
PostPosted: Tue Aug 23, 2011 5:42 pm
Or get a mate to drive next to you :)
PostPosted: Tue Aug 23, 2011 6:00 pm
Have a look here :
http://www.tomsminisite.co.uk/speedo_ca ... mid=250646
For some background on it all. TPM (turns per mile) can be found on the speedo face, right near the odometer.
cheers,
Jacob
PostPosted: Tue Aug 23, 2011 6:50 pm
thanks for the replies guys. from what i can tell it says 1408 tpm. which would throw it out by 9%. is there a way i can correct this with out it costing me a fortunte? or will i have to get another speedo?
PostPosted: Tue Aug 23, 2011 7:09 pm
There is a 140KMH Moke speedo with 800 turns/km, that is pretty close to a Cooper S's 1280 turns/mile (suits 3.44 diff and 10" wheels).
the 800 is marked on the front face..... :wink:
PostPosted: Tue Aug 23, 2011 7:35 pm
Some one measures speedo accuracy???? Not in NSW.
Run it against a GPS and draw up a correction chart.
Any instrument shop will calibrate your speedo - which is adjustable . The odometer is not "adjustable" so needs physical correction of the associated gearing (which is not too difficult).
Cheers, Ian
PostPosted: Tue Aug 23, 2011 7:38 pm
ok thanks guys ill test it with a gps and might just get it adjusted if not ill look for the 800 moke one.
cheers again guys much appreciated :)
PostPosted: Tue Aug 23, 2011 7:51 pm
The other common Moke 140KMH one is 860 turns/km (also is marked on the front face).
I put one in Barney (10" wheels) with a 3.64 diff, and it was spot on over the 5km test markers on the M4.
PostPosted: Tue Aug 23, 2011 11:18 pm
will definately have a look and see what i can find. thanks for the help :)
PostPosted: Wed Aug 24, 2011 12:10 am
Connect the speedo cable to a drill and try old and new speedo. If they both show the same speed at sthe same drill RPM - it'll fit. If not, you need to do the math as has been described.
