It is currently Sun Jul 20, 2025 3:44 pm
PostPosted: Thu Sep 08, 2011 9:50 pm
Has anyone got a bare mini shell to fit on a 6x4 box trailer, planning on picking a shell up his weekend but i'm not sure if it will fit on/in my trailer, ive measured the floor and it should be a tight fit with the guards sicking over the edge, is this a problem? Any info would be great
Cheer matt
PostPosted: Thu Sep 08, 2011 10:12 pm
It will fit on with two bits of 4x2. It will not fit in the trailer.
PostPosted: Thu Sep 08, 2011 10:41 pm
You would mean like this?
Just make sure the 2 x pieces of 100 x 50 are securely tied to the trailer and then the body shell is tied tightly to the trailer
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Sep 09, 2011 9:02 am
Smallest trailer a rolling shell will fit on?
PostPosted: Fri Sep 09, 2011 11:15 am
MinisPlus
I've put my shell on my 6x4 to transport it to and from the media blaster.
It went on fine. I did not use any wood under it, maybe it's just my trailer, but it sat there nice. It sat on top of the sides, not on the floor. A couple of ratchet straps, job done.
How can it be rusty when it's covered in so much oil?
PostPosted: Fri Sep 09, 2011 11:21 am
thanks guys :)
PostPosted: Fri Sep 09, 2011 6:38 pm
A mini is 10 foot by 4ish foot or 3m by 1.4m if you have wide wheels and flairs it may need to be around 1.5m wide.
PostPosted: Fri Sep 09, 2011 10:06 pm
I am wrong! :oops:
I have received a PM that has advised that a mini will fit in a 6x4 trailer.......as long as the shell is upside down!
:wink:
PostPosted: Sat Sep 10, 2011 12:46 am
Here's some of mine;
mini van without front cut.
another van
and a sedan
You'll see the sedan floor pan fits inside the top of the trailer to help locate it to prevent it moving around, the vans are a bit to long for this to work as well.
PostPosted: Sat Sep 10, 2011 10:40 am
Just be mindful that in Vic it is now illegal to have anything overhanging a trailer. Red flag or not. I know.
I had a polite and informative conversation with an officer on the side of the road last year.
Good fella he was too, the oversize wasn't the only issue...... :lol:
Image Image
PostPosted: Sat Sep 10, 2011 7:26 pm
all went well, thanks guys
PostPosted: Sun Sep 11, 2011 4:56 pm
I severely doubt the legalities of that set up, personally i wouldnt do it
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Sun Sep 11, 2011 6:53 pm
WOW, just noticed the pole sticking out even further. gee the red rag will help
UNFUCKENBELIEVABLE!!!! :evil:
