It is currently Fri Jul 25, 2025 6:15 pm
PostPosted: Thu Apr 14, 2005 10:46 pm
Yes, it's here in WA. They say that they are waiting for more parts to make the whole process more economical for them.
My previous crank (unwedged, also stroked) cracked. The mechanic took to it with a file and it cut away like butter. He said: "Moron didn't heat-treat it."
My new crank will be wedged and stroked, so I really want the heat-treating done. Just wish the bar-stards would hurry the f up.
Jonathan
PostPosted: Mon Apr 18, 2005 8:01 pm
Dr Mini ,
Here is the name and address of the heat treater I use.
HEAT TREATMENT AUSTRALIA
33 CARNN ST
GUILDFORD
PH. 96813050
FAX: 96813297
hope this helps,
Ian.
850 Morris Mini
Morris Mini Traveller
Mini sports Sedan
PostPosted: Mon Apr 18, 2005 8:24 pm
Thanks for that. :wink:
This 12G1505 crank is hardly used- std/std, and now 84.3mm stroke. Is it likely to warp during nitriding, and need regrinding? :cry:
More $$$ if so.....
PostPosted: Mon Apr 18, 2005 8:46 pm
Kev, they usually grow about 0.003" and warp about 0.008"
I'd be heat-treating it THEN finish grinding to size..... thats what they did to mine..... seems pretty good so far ! (withstood the famous Wakefield park Trip.....)
J
PostPosted: Mon Apr 18, 2005 8:48 pm
Once you have done your wedging, stroking and finish grinding, send it to be nitrided. During the process it does bend but don't dispare they straighten it and it comes back to you to give the journals a light linish with scotchbrite and fit it ready to do battle :D
850 Morris Mini
Mini sports Sedan
PostPosted: Mon Apr 18, 2005 9:26 pm
Ooo! I am interested too! how much Kev? did you find out?
Lillee - 1969 Morris Mini K
PostPosted: Mon Apr 18, 2005 9:35 pm
Oooo..sounds good...prices 8)
PostPosted: Tue Apr 19, 2005 10:26 am
Forgot to ad Heat treatment Australia's website.
http://www.heat.com.au
I get all the cranks nitrided for the motors I have built for this NB race car.
Also run either a 4 bolt centre main or at least a centre main strap
http://hot4s.my105.com/classified.asp?id=4084&latest=1
850 Morris Mini
Mini sports Sedan
PostPosted: Sun Apr 24, 2005 1:43 pm
I still haven't got it back. I'm going to ring this company directly (as MiniCraft here in WA organised it) and demand that my crank is done this week. This wait is ridiculous. I'll just take my business elsewhere and organise someone else to do it myself.
Jonathan
 Post subject: Shot Peening...
PostPosted: Sun Apr 24, 2005 8:12 pm
lisian_1275 wrote:
I think they are called St George Heat treatment? I will find my paper work and send you a post. May take over the weekend before i find it, if thats ok.
No problem.
My crank was stroked by Spiro, at St George Crankshafts, maybe related.. :?:
he's just around the corner where I work.. :lol:
just out of interest....is shot peening only for non bearing surfaces like rods :?:
and yes Nitriding or Tuftriding is only case hardening for maybe 10 thou :?: :?: ...I too have heard that a crank can be ruined if not done correctly... :?
 Post subject: Re: Shot Peening...
PostPosted: Sun Apr 24, 2005 8:17 pm
9YaTaH wrote:
No problem.
I know some racers (and well known Mini engine builders) who won't take the risk.
But I'll talk to Spiro this week.
Last edited by drmini in aust on Sun Apr 24, 2005 8:18 pm, edited 1 time in total.
 Post subject: Gruber??
PostPosted: Sun Apr 24, 2005 8:18 pm
lisian_1275 wrote:
I get all the cranks nitrided for the motors I have built for this NB race car. Also run either a 4 bolt centre main or at least a centre main strap
Charles Gruber's car :? :?:
Users browsing this forum: No registered users and 61 guests
