It is currently Thu Aug 21, 2025 7:48 am
 Post subject: Under carpet felt?
PostPosted: Mon Oct 03, 2011 8:23 pm
What do we fit under the carpet?
Replace the factory Felt or what other forms of sound deadening are available?
And where do you buy it from?
Normal carpet shop?
Not interested in sticking dynamat every where, just want something to add bulk under the carpets and trim.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Oct 03, 2011 8:27 pm
i went to clark rubber and got a roll of something (the name escapes me) but it was a silver sarki material on one side and black felt on the other. used that as base roof insulator and on the floor as well
71 Clubman 1100
PostPosted: Mon Oct 03, 2011 8:29 pm
I put this under the new carpet in my Leyland:
http://www.minisport.com.au/prod703.htm
1977 Leyland Mini Van - Sold
PostPosted: Mon Oct 03, 2011 9:08 pm
Get the proper Rover moulded underfelt from a Rover import if you can. It's brilliant.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Oct 03, 2011 9:17 pm
I've not seen this, what's it made of?
Other than that, I use the standard underfelt you get from any upholsterers shop and cut it to fit with a pair of scissors. You can get it in thick or thin I seem to remember.
I cut it about an inch undersize for the carpet its under so it doesn't poke out....
PostPosted: Mon Oct 03, 2011 9:18 pm
Hey Michael,
Contact me at work, I have a sample roll of underfelt that I think you will love! [email protected]
-Andrew
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
Minisport for all your mini parts
PostPosted: Tue Oct 04, 2011 6:41 am
dynamat is the only stuff to use
http://www.ebay.com.au/itm/DYNAMAT-XTRE ... 20bd28aecf
PostPosted: Tue Oct 04, 2011 8:32 am
High heel ninja
Use a removalists grey felt type blanket, its just the stuff to use.
Doogie
PostPosted: Tue Oct 04, 2011 8:45 am
dodge wrote:
Dynamat's great stuff, but you're wasting your money if you're only using it as a underlay. Dynamat stops the panels from vibrating, it's not designed to work as a sound barrier. Yes, it will work as a sound barrier if you plaster it everywhere, but I'd suggest installing a moderate amount of Dynamat in the middle of the panels in question, and then use a good underlay as a sound barrier. This will save your wallet, and probably some weight too.
PostPosted: Tue Oct 04, 2011 12:13 pm
i have a big box full of the factory carpet-underlay, just found the stuff in my shed clean-up :-)
PostPosted: Tue Oct 04, 2011 4:12 pm
underlay underlay yee haa
PostPosted: Tue Oct 04, 2011 5:33 pm
The local highschool i work at got new carpet in a few rooms recently and i got a heap of the underlay which is the heshiony original looking stuff.
I have stacks and stacks of the stuff, if you lived nearby i would give you a few rolls.
PostPosted: Tue Oct 04, 2011 8:27 pm
You must have an Alladdin's cave up there Matt :lol: , your always finding stuff :!: :lol:
PostPosted: Tue Oct 04, 2011 9:31 pm
Like Christmas every day - or an Alzheimer patient meeting new old friends everyday.
David L
PostPosted: Tue Oct 04, 2011 9:33 pm
I'll have a set Matt - PM me the price
David L
Users browsing this forum: No registered users and 195 guests
