It is currently Sat Jul 19, 2025 9:41 pm
 Post subject: ID plate
PostPosted: Sun Oct 16, 2011 6:23 pm
Here it is.. how do I shmick it without rooting it?
Got some spare time for indoor work on da old girl.[/quote]
PostPosted: Sun Oct 16, 2011 6:57 pm
oven cleaner
PostPosted: Sun Oct 16, 2011 8:46 pm
Morris 850 August / Sept 64
I wouldn't use oven cleaner, they often contain Caustic Soda (NaOH) which will dissolve the aluminium plate.
Better to gently scrape and 'ping' the paint off so as to retain the black on the chassis plate.
:P
Sir Alec! we are not worthy!
PostPosted: Sun Oct 16, 2011 9:12 pm
you only leave it on 10 mins, not a week.
PostPosted: Mon Oct 17, 2011 11:09 am
Brasso
PostPosted: Mon Oct 17, 2011 4:48 pm
Depending on the oven cleaner it may destroy the id plate in 10 minutes or it might just take the paint off. There are different types of oven cleaners.
PostPosted: Mon Oct 17, 2011 5:11 pm
You could try thinners or paint stripper to remove the paint and then polish with alloy polish or brasso or similar
I wouldn't use oven cleaner as it's caustic
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Oct 17, 2011 5:28 pm
I would be inclined to follow Grahams suggestion of carefully picking the paint off. The black background can come away pretty easily if your not careful.
Or just experiment on a small corner
PostPosted: Mon Oct 17, 2011 6:36 pm
Is it paint or grease stuff? I find it hard to tell from the photo.
Would warm or cold water make a difference at all? Harden/soften something? I'm no expert, just a thought.
I'd certainly follow the suggestion of trying a small corner first, the plates can't be replaced exactly as they came from the factory, so please be careful!
Saxon Green 850: http://www.ausmini.com/forums/viewtopic.php?t=62641
Nightfire Red 850: http://www.ausmini.com/forums/viewtopic.php?t=66555
PostPosted: Mon Oct 17, 2011 6:40 pm
try some "Prepsol" or "wax and grease remover" if its just cheap paint,. it might pull it off and and won't damage the plate.
Thats what i'd do :wink:
Dusk Blue
1964 850
Users browsing this forum: Bing [Bot] and 83 guests
