It is currently Mon Jul 21, 2025 1:32 am
PostPosted: Tue Oct 18, 2011 9:11 pm
Is it a large jnl crank stroked for small jnl rods?
Was the block originally for a lge or sml jnl crank?
Now with 2 extra ports!
PostPosted: Tue Oct 18, 2011 9:22 pm
1100S etc blocks (except Cooper S) are same dimensions, either big or small journal.
PostPosted: Tue Oct 18, 2011 9:55 pm
OK , I just read he had a stroker and not sure of the block / crank types so thought that could be an issue, having experiend this my self.
Cheers.
PostPosted: Wed Oct 19, 2011 7:16 am
Only issue is fitting an S crank into 1100S block or vice versa. Centre main cap width on S is 1/32" less than all the others (why, who knows...)
This means I have to surface grind the thrust washers in my [1300 auto block]1360 (as it has S crank)- but if putting 1100S crank into Cooper S you need to use +.030" thrusts then surface grind them to fit.
Users browsing this forum: Bing [Bot] and 78 guests
