It is currently Sat Jul 19, 2025 9:43 pm
PostPosted: Sun Nov 27, 2011 8:49 pm
ok guys having trouble with the rear subframe support pins cant seam to get them to budge are they threaded or or do i just hit them with hammer . Just cant seem to get them out any suggestions please.
They have probably been in there since 1962 :oops: :oops:
PostPosted: Sun Nov 27, 2011 9:21 pm
depends which ones you're talking about.... the subframes are held at the front with a pair of 1/2" head bolts pointing forwards, and at the rear, a pair of 1/2" head bolts pointing upwards. Undo those, and the subframe drops out
The big pins stay in the subframe
PostPosted: Sun Nov 27, 2011 10:15 pm
And if the frame is already removed from the car, the rear mounting pins are welded into the frame, the front ones have a nut holding them in hidden behind the trailing arm.
 Post subject: subframe pin
PostPosted: Mon Nov 28, 2011 5:50 am
thanks guys much apreciated :) :)
Users browsing this forum: 748rum and 88 guests
