It is currently Sun Aug 17, 2025 2:49 am
PostPosted: Sun Dec 18, 2011 5:19 pm
Hi i wanted to know what the differnce between a clubman s and a clubman sunshine? because im being told my is a sunshine
jake
PostPosted: Sun Dec 18, 2011 5:33 pm
Sunshine had a sunroof, a special vacuum operated one.
:D
PostPosted: Sun Dec 18, 2011 6:05 pm
What he said ^^^^^
Otherwise same as a Leyland mini s
PostPosted: Sun Dec 18, 2011 6:07 pm
Jake, a sunshines body # 022X2S2M09. Check your compliance plate, as your rego sticker can sometimes have a 5 in place of a S!
Shane
PostPosted: Sun Dec 18, 2011 6:40 pm
Shane
The Sunshine had the same prefix as a Mini S. You can't tell by looking at the compliance plate.
Does it have a sunroof?
PostPosted: Sun Dec 18, 2011 7:02 pm
Shane
is the sunroof on the inside or outside :?:
PostPosted: Sun Dec 18, 2011 7:33 pm
Finaly a question i can answer and know what i'm talking about.
The sunshine is a leyland mini s but with more extras. The sunshine came out with a sliding sunroof with stainless rails like in this pic, the visor should be trabsperant also this isnt the right glass
Because of the sunroof leyland added this reinforcement to the roof
The sunshine also had factory tinted windows, pinstripes down each side and some shiney decals that said sunshine in retro 70's writing.
I could go on for a while but i think i'll stop now
More info can be found here
http://www.miniexperience.com.au/filead ... nshine.pdf
PostPosted: Sun Dec 18, 2011 7:50 pm
Send me a pm if you want me to give more info
PostPosted: Sun Dec 18, 2011 9:22 pm
& it`s not a "Clubman sunshine",,, a "Clubman" is a much earlier model with hydrolastic suspension & 1098cc engine & & & ,,, it just so happens to "Look" very much like the same car,,, but it`s not,,,, clubmans stopped in 1972
so if it`s 1973 or later then it would be a a "Leyland mini" or a "Leyland mini S" or a "Leyland mini sunshine" or a "Leyland mini SS" or a "Leyland mini LS" or ,,,ah you get the picture :-)
