It is currently Wed Jul 23, 2025 1:57 am
PostPosted: Thu Apr 21, 2005 5:46 pm
guys, noticed this arvo that under braking i can hear a creaking sound at a point in every revolution of the disc..... is it a warped disc, busted seal or caliper/pad problem??????
Thoughts.............
I got nuthin......................
PostPosted: Thu Apr 21, 2005 5:48 pm
Suspension problem??......
PostPosted: Thu Apr 21, 2005 6:34 pm
Hmmmm i am certain it is something brake related 9YaTaH, as it only happens under braking, no noises whilst normal driving :?
 Post subject: Brakes...
PostPosted: Thu Apr 21, 2005 9:46 pm
Hmmmm...thats OK....a suspension fault like a slightly stuffed or loose ball joint may only be heard when the brakes clamp and force the suspension to move forward or whatever....its just a thought....front end noises in cars can be very deceptive :idea:
Have you checked your caliper bolts for tightness :?:
Have you checked your pads are located correctly and still have plenty of meat on them :?:...low pads can cause some odd effects...sticking pistons/slides etc
Is the hub nut tight :!:
Are the disk thicknesses OK :?:
PostPosted: Thu Apr 21, 2005 9:57 pm
Car is less than 1000klms old from a full resto....... everything is new :?
PostPosted: Thu Apr 21, 2005 10:01 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
could need all the bolts retesiond
makka
PostPosted: Thu Apr 21, 2005 11:39 pm
But things do happen. Loose hub nuts are a good noise maker. Some modern pads make odd noises at very low speeds. Our Transit vans at work make horrible noises which sound like groaning sounds which gets worse as they get hotter.
Chris
Everything I like is either
