It is currently Mon Jul 21, 2025 8:42 am
Post new topic Reply to topic  [ 114 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Thu Nov 10, 2011 9:14 pm
it's a great box to get :)
im waiting on my last parts and my front mount rad then it's time to bolt this baby all up, it's all bolted up, but i need the proper ring gear on my high torque starter to make room get get this all working right.
pristic wrote:
Hey Nick,
I got a 10kg box in the mail today - wonder what it could be :-)
Just waiting on the boost stub for the throttle body from the UK and ill start installing.
Boy oh boy there are lots of parts in my kit (iinc all the boost/turbo stuff)
Enjoy your holiday mate
Peter
PostPosted: Fri Nov 11, 2011 10:37 am
my last little update.
my front mount radiator ;)
Uploaded with ImageShack.us
PostPosted: Sat Dec 03, 2011 1:04 pm
Hi Nick,
how the front mount radiator works with your air con setup(if you have). do you have some pictures.
Since light travels faster than sound, people appear bright until you hear them speak
PostPosted: Sat Dec 03, 2011 1:28 pm
hey mate.
you can give me a call but i have not worked out what do to yet either run the rad in front of the radiator fan sucking or run behind the car or run it where the radiator use to be with a duct for cool air & another thermo fan..
PostPosted: Fri Dec 23, 2011 8:54 pm
only a little update not been working on the car.. christmas time is always mental for me and lots of shows and busy making music.
but i have the car up on stands now & put some new fuel lines in.
i have mounted up all the injection so it's very close to starting her back up.
miss this car gonna really jump into it soon.
PostPosted: Wed Feb 08, 2012 5:46 pm
so have you jumped in yet? :D
1963 850 - laid up
PostPosted: Wed Feb 08, 2012 7:16 pm
Funny you say that I spent 2 days on
It last week, Matt read was kind enough to help me sort my starter out
So hopefully the high torque starter has the proper gear for my verto ring gear now.
I'm charging up the déka battery hooking up the pipes for fuel
And gonna get the crank angle sensor right and kick
It into life.. :)
PostPosted: Wed Feb 08, 2012 8:33 pm
Good luck with the 1st start Nick
Always very exciting after spending so long on the build
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Mar 17, 2012 1:58 pm
slight little update
the other day i got my new front mount rad, I changed direction.
I did not want to cut the body with the other rad no & my aircon i would have had to, this new one involves no cutting.. :D
ebay bargain, just getting one or the pipes modified & moving the cap to the back.
everything is now plumbed in & hopefully monday will fire her up for the first time :)
PostPosted: Sat Mar 17, 2012 5:35 pm
happy to be proven wrong, but it doesn't look much like that'll have enough capacity, cores or cooling area to do anything other than get in the way of the starter motor & clutch....
PostPosted: Sat Mar 17, 2012 5:59 pm
Supercharged
yeah i agree, that doesnt look up to the job.
PostPosted: Sat Mar 17, 2012 8:55 pm
It's alloy, it's the same size as a Morris 1100
Rad bigger the a mini, it's in the front and will get plenty of air
I doubt it will have any problems, I'll run a extra expansion tank also..
The bike it come from is a 150bhp odd, I think it will be fine
I'll let you all know, as I'm putting one on the swift gti mini also.
PostPosted: Sat Mar 17, 2012 9:12 pm
I'm looking at the thickness of it, the fact that there's only one core and the amount of space between the gills
NG wrote:
The bike it come from is a 150bhp odd.
that doesn't mean much - motorbikes don't have nearly as much work to do. Do you think the brakes from a 150bhp motorbike would stop a 150bhp car?
motorbike engines are alloy, which means they have a lot of cooling through the metal itself. Motorbikes weigh a lot less than a car and have significantly less drag, meaning the engine doesn't work as hard to accelerate or maintain speed. Motorbike engines don't have heavy flywheels, heavy gearboxes, heavy wheels, big alternators, air conditioners or superchargers to drive... different needs altogether
NG wrote:
I doubt it will have any problems..
I'll let you all know.
like I said, happy to be proven wrong :)
PostPosted: Sat Mar 17, 2012 9:48 pm
I think it will be ok, but
Only one way to find!! Try it :D
I'll report back
PostPosted: Tue Mar 20, 2012 8:22 pm
Hi NG,
Nice to see the progress. If normal Mini size radiator works fine on the side bigger alloy one at the front will work better, Most of the new cars do not have big opening at the front as much as Mini.
