It is currently Sat Jul 19, 2025 7:41 pm
 Post subject: 1275LS motors?
PostPosted: Sat Jan 21, 2012 9:22 pm
A lad was trying to say that 1275LS's came standard with a+ motors.
This lads a real loser, so I dont believe him but can someone confirm/deny this?
Cheers Brenton
PostPosted: Sat Jan 21, 2012 9:25 pm
They had so-called A+ timing covers (with tensioner) and A+ rockers, 12G1316 smog head, that is all... block [edit- and the whole bottom end] is A series.
I believe the late 1275 Mokes got A+, I had one in Barney.
Last edited by drmini in aust on Sun Jan 22, 2012 9:04 am, edited 1 time in total.
PostPosted: Sat Jan 21, 2012 9:38 pm
Some late Mokes got A+ gear sets on non-A+ blocks (well the 998 one I bought had that combo anyway).
PostPosted: Sat Jan 21, 2012 9:44 pm
What the doc said.
And they had heavy conrods with counterweights
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Jan 22, 2012 9:17 am
The 1275LS block is not the same as an 1100S block but it is not an A+ block.
My 1275LS motor has the timing cover with the hump for the tensioner but there is no tensioner in it. I don't know if it was ever fitted, I can't remember seeing any signs of it.
PostPosted: Sun Jan 22, 2012 9:19 am
They have an A+ layshaft in the box, too?
PostPosted: Sun Jan 22, 2012 9:40 am
Mine had the big bearing drop gears and the later layshaft box. But the motor had signs of being blown up (one odd con-rod and a few scars on the block) so there is a chance the box may have been changed.
I got the car in 1984 so anything could have been changed in those first six years.
PostPosted: Sun Jan 22, 2012 10:58 am
The 1275LS`s weren`t meant to have A+ boxes,,, not saying that some weren`t fitted with them, but i suspect it would have been very very very rare,,, (notice i used 3x "very"`s there)
the late mokes got A+ boxes & donks for sure
but the LS`s were pretty much the (What i call) "Inbetweeny" blocks ,,, as in inbetween 1100S blocks & A+ blocks -->(As morris 1100 said with the lump in the block for the extra bolt for the tensioned "Type" blocks but no extra webs like the A+ got) & not "ALL" of them were even "inbetweeny" blocks either, early ones were just like 1100S blocks but with LS numbers stamped
PostPosted: Sun Jan 22, 2012 12:06 pm
Ok thanks everyone, thought i was right and the lad was just producing what usually comes out of his mouth.
Next time he says it i can tell him what for :lol: :lol:
Thanks everyone
Brenton
PostPosted: Sun Jan 22, 2012 2:24 pm
Mods rock!
The A+ Engine was developed for the Metros. The Gearboxes first appeared in the UK very late in 78, the engines mid to late 79. The Mokes didn't see the A+ Gearboxes until ~Sept / Oct 79 and the A+ Engines until Oct / Nov 79.
One of my Mokes had A+ Gearbox, pre A+ Block and A+ Rods. This one was plated October 1979. I bought it with 8 000km on the clock. It was as it came from the factory. The 1275 LS's were too early, only just, for the A+ stuff.
