It is currently Sun Jul 20, 2025 8:21 pm
PostPosted: Tue Jan 31, 2012 6:58 pm
mickmini wrote:
michaelb wrote:
Sorry! I'm bored and thought I would see who was awake. :roll:
I know you are correct but my response is still "why"
Its amazing how a man was sent into space using 50's and 60's technology. :?
Computer on Apollo had a whole 64KB of RAM so I heard! :shock:
Naah, that was the space shuttle.
So, what did Apollo have then, an abacus? Do tell... :wink:
PostPosted: Tue Jan 31, 2012 9:34 pm
Lillee wrote:
I bet it had a whole 30bhp, fwoah!
Would have been well under 20 mate. As it was just 1/2 a 948.... (which had 37bhp I think).
While I agree with the Doc, I reckon it could have been further developed. This is just a parallel twin and the Brits had a lot of experience with them in motorcycles. A 490cc Triumph Tiger Daytona could put out over 40bhp as standard. Although that wouldn't be a pleasant car to drive.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Tue Jan 31, 2012 11:10 pm
[Thread hijack]
State of the art in reliable, robust, never fail computer engineering in the 60s was stuff like ferrite core RAM and tiny nickel-iron cores woven together with thousands of copper wires and encapsulated in plastic for ROM. 64K of that stuff would weigh a fair bit and be very bulky. Same sort of thing used in US Navy shipboard computing (not so much any more :wink: ). It needed to be on the trailing edge of technology for reliability sake, but leading edge to make it as lightweight as possible. The stuff that was in the Apollo rockets had to survive extreme vibration and accelerations. Remember that programs were written on punch cards back then and they were just moving to paper tape and - OMG - magnetic tape. If a programmer stuffed it up, they would literally cut the tape and splice a "patch" into the program tape - this is where the term comes from. The program was loaded into high density core rope to make the equivalent of what we call firmware today. The program determines the weaving or wiring sequence of the rope. So they had to have a "perfect" program before weaving and sending people of into space with it. Even then they relied on the astronauts feeding in data and making decisions on what the computer fed back - very much a semi-auto system.
Check this 1974 article out for more details - http://history.nasa.gov/afj/compessay.htm
You are a machinist Kev(OK a fitter), so you will understand the beauty of the mechanical computers that were around in the 40's and 50's> hand machined cams and toroids that represented sin, cos, tan, exponential, integrating and differentiating functions. This was the base that the Apollo programs predecessors were based on. Good old analogue mechanical stuff. Going for the "new" kind of computing was a big risk for the Apollo program, but the only way they would ever get it light enough to get to the moon.
[/hijack]
michael
PostPosted: Tue Jan 31, 2012 11:22 pm
I heard somewhere that they had three systems. One and two back ups.
The Harbour Bridge, all those simultaneous equations on slide rules to make it join in the middle.
Not like our engine mounts though.
I guess someone's slide was in back the front when they designed them.
PostPosted: Tue Jan 31, 2012 11:23 pm
PostPosted: Wed Feb 01, 2012 8:08 am
TheMiniMan wrote:
yeah & i would have certainly Fully defected to the volksy ranks
" Matt the VolksMan" ....sorry don't ring for me
David L
PostPosted: Wed Feb 01, 2012 9:19 am
Plenty of room under the bonnet, tho' I would have waited for the 650cc up grade.
PostPosted: Wed Feb 01, 2012 10:40 am
If you believe the story about the XC9003 and "orange box" prototypes being a few inches narrower than the final car then the extra space could have been valuable. I agree, a 650cc version would have been a useful improvement. It still would have been terribly underpowered though, unless the body was a lot lighter.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Wed Feb 01, 2012 5:21 pm
is there a working one of these anywhere in existance. I have never heard of a two cylinder block, let alone seen one.
And Appollo had less computing power than your digital watch.
PostPosted: Wed Feb 01, 2012 6:28 pm
Thanks mickmini, that NASA link was very interestinggggg. :P
BTW, I'm a fitter & machinist (among other engineering quals...) :wink:
PostPosted: Wed Feb 01, 2012 8:52 pm
I wonder what the Cooper S version might have had...if John Cooper touched it at all..
PostPosted: Wed Feb 01, 2012 9:05 pm
Extra vibration :lol:
Nothing vibrates like a British twin.
PostPosted: Wed Feb 01, 2012 9:15 pm
An A series as per his Formula Junior cars :P
PostPosted: Wed Feb 01, 2012 9:38 pm
True, but that's partly because British twins are almost all 360° engines, both pistons go up and down together. Its probable that the prototype twin was a 180° engine with one piston coming up as the other goes down. 180s vibrate a lot less but you get a rocking couple on the crankshaft, so you need better bearings. 180s tend to be able to rev more.
The current model Triumph Bonneville has a traditional 360° arrangement so that its exhaust note sounds right, but it also has balance shafts, a bit like a camshaft with a big lumpy lobe on it. The spinning balance shafts counteract the vibrations of the two pistons going up and down together and make it very smooth.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Thu Feb 02, 2012 12:27 am
660 cc is the same as modern Japanese kei cars. Surprising someone hasn't tried to adopt the dohc 660cc from the Suzuki cappuccino. Can put out more than double in race trim (120kw or so)
Users browsing this forum: Dan69s, Scoop and 71 guests
