It is currently Sun Jul 20, 2025 4:30 pm
 Post subject: Lower control arm bushes
PostPosted: Wed Feb 01, 2012 7:01 pm
What do you like? I had a look at what is available and now I'm confused.
PostPosted: Wed Feb 01, 2012 7:04 pm
IMO the lurethane ones are all rubbish for a road car. They either crack up or flow out of shape. I use the original compressed live rubber ones, never had a problem.
PostPosted: Wed Feb 01, 2012 7:09 pm
This space for rent
From memory, there are two types - tapered and parallel, one for early cars and the other for later. Can't remember which is which :roll:
PostPosted: Wed Feb 01, 2012 7:13 pm
Early ones are flat.
The standard ones for the tapered bottoms don't have a lip, but other ones do?
PostPosted: Wed Feb 01, 2012 7:25 pm
This space for rent
Yeah, I think that's right. The ones I got with my adjustable lower arms were like little barrels, with steel inner sleeves. No outer lip.
PostPosted: Wed Feb 01, 2012 7:42 pm
Barrel, that's a great way of describing them. They are the standard ones for the taper type later lower arm. I'll just get them again I think. I put them in the Moke.
PostPosted: Wed Feb 01, 2012 8:39 pm
Mods rock!
As an alternative to (crappy) Urethane ones, there are hard rubber (real rubber!) ones available for the post 68 cars. They still have the steel insert too.
PostPosted: Wed Feb 01, 2012 8:47 pm
Convert them to a spherical bush.... the centre of a rod end! It is easy to do!
PostPosted: Wed Feb 01, 2012 9:19 pm
I believe illegal for road use. But fine on the track.
PostPosted: Wed Feb 01, 2012 9:27 pm
Adjustable arms are as well... but this conversion is very easy to hide with factory arms!
Rob
Users browsing this forum: Majestic-12 [Bot], minimanic and 79 guests
