It is currently Sat Jul 19, 2025 7:23 pm
PostPosted: Tue Feb 28, 2012 3:10 pm
Forum Graffiti
A quick question - what's the best way to removing factory brazing on a Mini? I've removed the front apron and at the moment have a small half inch high section left from the wheel arch to the bonnet latch panel. I know the apron was spot welded to the wings but there is some brazing on either end (wheel arch and wing-latch panel) which I need to remove nicely.
Hope that makes sense.
PostPosted: Tue Feb 28, 2012 3:21 pm
An oxy would be ideal if you could get your hands on one
PostPosted: Tue Feb 28, 2012 3:34 pm
Forum Graffiti
An oxy would be perfect, unfortunately I don't have access to one. Would a butane torch or similar get enough heat into it? Or is there another portable tool I could use?
Oxy, or an LPG or butane torch.
Hot air gun won't work- too cool.
PostPosted: Tue Feb 28, 2012 3:38 pm
Forum Graffiti
This looks like it might fit the bill --- http://www.ebay.com.au/itm/HIGH-TEMP-HI ... 519db597de
PostPosted: Tue Feb 28, 2012 3:53 pm
Might work but I think too small. I was thinking of a plumbers gas torch (Primus, etc).
I have oxy/LPG- it'll do anything except fusion weld with steel rod.
PostPosted: Tue Feb 28, 2012 4:55 pm
I used a small die grinder to get mine off
Its a pretty soft weld
PostPosted: Tue Feb 28, 2012 5:29 pm
Forum Graffiti
I'll let you know how it goes :lol:
I got one that pops on top of a butane canister.
If it reaches near its advertise 1100C with any luck it will at least soften it up to dig out.
PostPosted: Tue Feb 28, 2012 5:43 pm
Yeah those sort are OK I have a Ronson one. :D
Then the Ronson style canisters disappeared and it won't fit current ones. :(
