It is currently Fri Jul 18, 2025 7:51 pm
PostPosted: Tue Feb 28, 2012 9:00 am
howdy lads
Im looking to tap into some alloy parts, i bought from specialist components.
I have no idea what reacts with alloy? if i use a steel bolt thats will fuse right?
what about a titanium bolt? stainless? or is it best just to slam it with cooper paste.
PostPosted: Tue Feb 28, 2012 9:07 am
Steel is fine, S/S is too (but may be weaker depending on grade).
Don't use copper paste, dip the bolts in lanolin or Permatex/Loctite #3 gasket cement.
Works fine on outboard motors (with S/S studs). :wink:
PostPosted: Tue Feb 28, 2012 9:29 am
why not copper paste? i have some of that zinc paste at home the silver stuff would that work?
PostPosted: Tue Feb 28, 2012 9:35 am
Copper and aluminium are bad companions. Add water and you will promote corrosion.
That silver paste may be nickel, not zinc (if it is anti-seize compound).
Outboard motor makers (Johnson & Evinrude) dipped all their threads in lanolin (wool fat) before fitting.
I used to use Permatex #3 gasket cement on these when replacing. It seals the water out. 10 years later, I could still screw them out.
I still use it on Mini thermostat housing studs.
PostPosted: Tue Feb 28, 2012 9:39 am
ok cool thank you doc :) ill do that then! yes i have the nickel one sorry. would that work?
PostPosted: Tue Feb 28, 2012 10:26 am
Nickel anti-seize would be better in alloy than copper.
PostPosted: Tue Feb 28, 2012 11:27 am
NG wrote:
howdy lads
Being nosey but, wot you fitting ?
PostPosted: Tue Feb 28, 2012 4:25 pm
rear alloy hubs & alloy mini fins to lighten up the mini a bit,
might go alloy rear arms not sure yet or im going force racing split rims and leaving it at that.
PostPosted: Tue Feb 28, 2012 6:32 pm
Alloy doesn't particularly like stainless steel unless you properly isolate the joint. Especially if you're anywhere near a marine environment; the salty air will trigger corrosion.
PostPosted: Tue Feb 28, 2012 6:39 pm
so would titanium be better?
PostPosted: Tue Feb 28, 2012 7:01 pm
Don't know if it's different for drums but once I finished bleeding from my knuckles and screaming profanities I finally got the remains of the screw out (with a bloody big hammer and impact driver, which I twisted in the process) I threw that screw away as I reasoned the clamping force from the wheel nuts would be more than that puny screw anyway. And now if I ever have to change discs again it's much easier, as that screw won't ever get seized again.
PostPosted: Tue Feb 28, 2012 7:14 pm
+1 for what the doc said.
PostPosted: Tue Feb 28, 2012 7:18 pm
[quote="drmini in aust"]Copper and aluminium are bad companions. Add water and you will promote corrosion.
Question for you 'drmini' slightly off topic but seeing we are discussing anti seize, I am going to change the long life iridium spark plugs in an all alloy V8 shortly, I was going to use the jar of copper based anti seize I have until I read this thread, any suggestions as to what to use? They are long life plugs so will be in the alloy for like 80,000km and a lot of years.
Appreciate your thoughts.
PostPosted: Tue Feb 28, 2012 7:23 pm
I would use nickel anti-seize, it is better for high temps than copper anyway.
I use the nickel one on the Y-piece of my Maniflow LCB. Hopefully it won't seize on like it did with the copper one. :x
PostPosted: Wed Feb 29, 2012 7:55 am
Thanks, I've done the same but not split rims. And I used KopraCote on the drum screws so I think I'll check 'em out :roll:
Users browsing this forum: Majestic-12 [Bot] and 83 guests
