It is currently Tue Aug 19, 2025 5:31 am
 Post subject: fuel pump
PostPosted: Wed Mar 14, 2012 4:59 pm
hi all just a small question. Where do people or how do you guys mount a facet silver top pump like what minisport sells. Cheers
PostPosted: Wed Mar 14, 2012 6:27 pm
I managed to mount mine vertically on the subframe near where the Cooper s pumps are mounted
My car is not a daily driver so not too worried about water damage although it is up out of the way, just.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Mar 14, 2012 7:05 pm
I mounted mine on the rear subframe (on the horizontal face) under the tank. I used two holes that were already there, made up a right angled bracket which I mounted to the subframe with exhaust cotton reel mounts, and bolted the pump to that on a 45deg angle as per the pump recomendations.
PostPosted: Wed Mar 14, 2012 7:11 pm
ok i think ive got you any photos by any chance
PostPosted: Wed Mar 14, 2012 7:13 pm
I used the facet square one, it bolts straight onto a Mini centre zorst mount. Drill a 5/16" hole through the subby web and fit a nyloc nut, all done.
PostPosted: Wed Mar 14, 2012 7:24 pm
thanks fellas i will have a fiddle
PostPosted: Wed Mar 14, 2012 7:30 pm
Mount it on a 45 deg angle like I mentioned and like the doc's photo if you can (really no reason why you shouldn't be able to).
Users browsing this forum: No registered users and 274 guests
