It is currently Mon Aug 18, 2025 3:44 pm
 Post subject: Dead clubman
PostPosted: Fri Apr 13, 2012 10:34 pm
Hey guys I got a dead clubman, she is a 1048. Was running good on Saturday, fuel was low but not out. Went to get in Sunday and nothing, turns over fine but no spark. Won't fire at all. What options to check and causes. Thanks for your help
PostPosted: Fri Apr 13, 2012 10:43 pm
Do you mean literally no spark? Spark at the sparkplugs?
PostPosted: Fri Apr 13, 2012 10:46 pm
I have not checked plugs yet. I mean when you turn her over there no fire, just turning over if that makes sense. It's weird cuz was running fine day before
PostPosted: Fri Apr 13, 2012 10:57 pm
Check to see there's spark at the spark plugs, pull a lead off and have a buxom and attractive assistant turn the car over while you administer shocks to yourself holding the lead close to the block.
You will also need to check there's fuel in the fuel bowl (remove the three screws) caused by the low fuel tank level and perhaps a draining back fuel pump.
PostPosted: Sat Apr 14, 2012 10:30 am
Took number 1 lead off turned car over. Can't see a spark inside lead and can't really tell from pushing lead on block maybe I Antoine it right. Took the top off su carb. The dome bit with three screws. Now I got no idea what I'm looking at lol
PostPosted: Sat Apr 14, 2012 10:41 am
Not the dome, but the fuel bowl on the side. Should be petrol in there. If there's not, get a jerry and fill it up about 2/3rds of the way and put the cover on. It might be that the petrol in the tank is so low that the fuel pump has lost prime.
If there's no spark then you will have a problem with the distributor or coil.
You will need to work out which one it is before you can have a go at fixing it.
PostPosted: Sat Apr 14, 2012 10:44 am
Ping MiniMafia (Josh) for advice, he still lives near Hobart (Richmond) I think. :wink:
PostPosted: Sat Apr 14, 2012 10:46 am
Petrol in the bowl is the short answer !!!!
Just give the ignition a quick hit on the starter and see if pumps petrol. Dont do it for long though as you dont want petrol plashing every where if it is pumping though. Just a quick hit.
Oh - just twigged - the domed thing - thats the bell of the carby - put that back on and make sure the thing inside it rises and falls smoothly once its back on.
What was being spoken about was the fuel bowl beside it - to see if it is full of petrol.
Mike
PostPosted: Sat Apr 14, 2012 11:12 am
here my carb
where is the float bowl?
EDIT: EDIT: Yours looks different to mine. Disregard what I've said below.
EDIT: Just realised you snuck in a photo before I posted mine. Have a look at the other side of your carb for the fuel bowl.
Just for clarification:
The red square is your fuel bowl. The green square is the fuel line coming from your tank - yours may well have a filter attached to this hose. Have a quick check to see if it's full of fuel or not before you take the top off your fuel bowl. If it's empty, then chances are your fuel bowl is also empty.
If you wanted to, you could replace this filter if it looks old as well as it could be clogged up, restricting fuel to the carby. They're only a few bucks from your local auto store.
'77 Leyland Mini Van
PostPosted: Sat Apr 14, 2012 11:14 am
also is there a way to test coil or dizzy with a multi meter or something?
PostPosted: Sat Apr 14, 2012 11:17 am
umm i got none of that, i got a hose right from fuel pump to carby as u can see in pic
PostPosted: Sat Apr 14, 2012 11:20 am
I had a feeling it was a HIF carby.
No the HIF wont have a fuel bowl off to the side. It has an internal fuel bowl.
How long has it been since this car was driven and used regularly ?????
Mike
PostPosted: Sat Apr 14, 2012 11:21 am
saturday it was running, last sunday it died. its driven 3 times a week
PostPosted: Sat Apr 14, 2012 11:24 am
Sorry, mate, didn't mean to steer you in the wrong direction, I'd take off the fuel hose and do as Mike suggested. See if your pump is working. If you've got fuel, then it must be electrical.
Users browsing this forum: Bing [Bot] and 341 guests
