It is currently Tue Jul 22, 2025 7:50 pm
 Post subject: What clutch to get?
PostPosted: Thu May 24, 2012 9:29 pm
I'm building a twincam 1360 which should make around 100+ atw. The car is a daily drive but always gets driven hard. What sort of clutch should I look at getting that will be able to handle the power and abuse but not be to hard on my foot in stop start traffic?
PostPosted: Thu May 24, 2012 9:33 pm
I have an orange dot in my supercharged engine which seems OK
Bit heavier than the standard cooper s type but not too bad in light traffic
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu May 24, 2012 9:44 pm
I second the orange dot. I have one in the 1412 which has 112ft/lb torque. And another in the 1360.
Set them up so the diaphragm spring is flat when assembled.
See http://www.minimania.com/web/SCatagory/ ... ticleV.cfm for assembly details and procedure.
PostPosted: Sat May 26, 2012 2:59 pm
I would go a verto RTS clutch
Twin
Spring clutch made on turbo minis
PostPosted: Sat May 26, 2012 3:07 pm
you should find the orange to be fine for what you want
the verto system is too heavy in my books
& even if you were turbo charging, i`d just use one of our "Re-pivoted" systems
PostPosted: Sat May 26, 2012 11:27 pm
All right so where do I go to get these? is it just as simple as asking the local auto parts store for a mini orange dot clutch or what?
PostPosted: Mon May 28, 2012 8:42 am
Any mini parts supplier should be able to help or ring Karcraft in Sydney and they can ship one out.
I doubt that Repco or Auto One would keep these in stock? They may have a standard clutch kit.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon May 28, 2012 9:22 am
Karcraft keeps the AP orange dot (rally) diaphragm in stock and also the AP comp (bonded & rivetted) clutch plate, you won't find them cheaper out here.
They also keep the AP grey dot (race) diaphragm but IMO not needed for a road car.
PostPosted: Mon May 28, 2012 10:36 am
I also run orange dot + AP sintered clutch plate on my 1430
They don't come apart like some of the Cooper S (blue dot) plates.
IMHO grey dot is for race only cars.
Users browsing this forum: Bing [Bot] and 68 guests
