adios57 wrote:
I did not do a bench bleed of the master cylinder.
I don't have any spare bleed screws.
The Master had some pitting at the lowest point of the cylinder just a few mills above the circlip recess.
The old seals did not show the marking of a scored cylinder or any breaks and were still flexible.
I can do the bleed again using vice grips or small g clamps on the front and back flexible pipes. I put the new back ones on when I had the rear subframe out for the new boot floor.
I am doing the 2 man bleed with my brother the owner sitting in while I do all the scrambling and grovelling.
I did buy a bleed kit but found the so called non return valve was crap so I am using clear hose 2 types and a glass jar with all fluid not being re-used.
The gurgling sound of the master under movement makes me think it is the master.
I did adjust the brakes up on all wheels to tight and then 1/8 turn off.
Pedal height should be up not down where Fred Flintsones feet go.
Thanks for the replies they are appreciated.
The car has the sticker The bitch bites on the back and so far it is really biting me.
I'm not suggesting bleeding with the vise grips, I mean putting the vise grips on the hoses, and testing the pedal. This will isolate the master cylinder from the wheel cylinders, and will rule out anything near the wheels.
I would recommend bench bleeding the mc before putting it in the car, because the pedal may not push the plunger all the way along the bore. If the mc hasn't been bled, there may still be air in there, which would explain the gurgling.
I bought a 1 man bleed kit too, and I figured that most cars have more fluid moving than a mini, because I didn't have much luck with mine either. I think I'll buy some kind of a power bleeder, I hear the gunson's ezybleed is pretty good.
