It is currently Sun Jul 20, 2025 9:19 am
PostPosted: Thu May 31, 2012 3:34 pm
I received my new Smiths/ caerbont automotive tachometer today and i am having problems wiring it up to my electronic ignition.
Can someone tell me what i am doing wrong?
Pin 1: I am not sure what this does
Pin 2: i will hook it up to my lighting loom
Pin 3 i am connecting to the + of the coil
pin 4: i replaced ping 3 with this
pin 5: done that
pin 6: i connected it straight to my fuse box which comes off the alternator.
The little switches on the back have been set up to a 4cyl.
I have tried it and all the needle does is bounce around staying under 1000rpm and after 10 seconds just shuts off...
So what goes where?
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Thu May 31, 2012 3:46 pm
This space for rent
The tach pin 3 (or 4) needs to be connected to the same side of the coil as the distributor, which from memory is the '-' side. The '+' side of the coil should be fed from your ignition switch.
Likewise the +12V power (pin 6) should also be connected via the ignition switch, so that the power to the tach is cut when the ignition is turned off. Otherwise it's constantly powered.
PostPosted: Thu May 31, 2012 3:48 pm
I will give that a go and report back :D
Thanks.
PostPosted: Thu May 31, 2012 3:58 pm
Perfect! Pin 3 was the answer.
Thanks.
One more question.. off topic..
Do you know where the mechanical oil temperature gauge plugs into on a mini?
PostPosted: Thu May 31, 2012 4:13 pm
You need to drill out the sump plug I think??
So... I'm Seifer
PostPosted: Thu May 31, 2012 4:15 pm
On the front of the block, at the opposite end to the temp sensor.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Thu May 31, 2012 4:21 pm
I read something like that on the minispares website but i thought wtf.. That can't be right.
@Ryan: I will have a look for it :D
PostPosted: Thu May 31, 2012 4:37 pm
The one Ryan is referring to is the oil pressure. You probably could get a reading from there but If you want a true reading you need to go to the sump.
So... I'm Seifer
PostPosted: Thu May 31, 2012 7:33 pm
There is an adapter that goes into the sump plug that can read oil temp.
PostPosted: Thu May 31, 2012 7:35 pm
Not worth the hassle to be honest.
I will also need to get a gauge pod and drill more holes.
I have put it up in the for sale section.
Users browsing this forum: No registered users and 67 guests
