goodie wrote:
Retrace your steps Danny, it wasn't leaking before , but now it is , what have you
changed , removed / replaced ? . Follow the leak from the bottom to the top and you should find your leak . From the vid it appears to be pumping a fair bit of oil about so be careful when you run it , make sure you have enough oil on the dipstick .
It certainly is possible that the Rocker Cover gasket has moved as" awdmoke" said , if so
it will p!ss oil down the back of the engine .
Hi guys,
Sorry for not updating it sooner.
I found the problem...
The plastic pipe that runs from the oil pressure gauge to the block got caught under the manifold and must of burnt a hole in the pipe and oil was gushing out onto the driveshaft /cv joint in turn spinning the oil onto the exhaust manifold.
Easy band aid fix was just the plastic hose.
I am off to ripco to see if i can source another pipe / fitting.
Does anyone know places that are open on a Sunday located in Sydney that can make up some oil cooler pipes? I purchased a clubman oil cooler pipe for the mini and its a bit to long and the standard pipes are not long enough.
http://www.flickr.com/by_danCurrent: 1970 Mini K 2014 Focus ST
2014 Land Rover Defender 90
