It is currently Thu Jul 31, 2025 9:29 am
PostPosted: Sun Jul 15, 2012 10:40 am
Ok they were working but now their not... I haven't changed anything they just stopped all of the sudden. Fuses are ok.
Any ideas people?
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Sun Jul 15, 2012 3:04 pm
Pull the fuses, clean all the copper blades on the fuse holder, ditto all the wire spade lugs attached thereto.
PostPosted: Tue Jul 17, 2012 9:19 am
well it appears you now have a dedicated drag car - straight lines, dry weather only :P
PostPosted: Tue Jul 17, 2012 9:55 am
:lol:
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Tue Jul 17, 2012 10:56 am
This used to happen to me, and it was a simple case of tightening the fuse box. Take the accessories fuse out, and push the holding tabs in a bit to tighten the clamping of the fuse. If anything is rusty or corroded, cean it up with a bit of fine sandpaper.
PostPosted: Tue Jul 17, 2012 11:19 am
Cheers. I've been busy lately but hopefully today or tomorrow I will do this. I will let you know if It's the cause.
Cheers Pete.
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Tue Jul 17, 2012 4:57 pm
Resident Haemorrhoid
and prepare a suitable sacrifice for the Lucas God that he might smile favourably on your Mini and bring the letrics back to life :wink:
mtsmini wrote:
Tombo wrote:
 Post subject: Simple tool .
PostPosted: Tue Jul 17, 2012 10:32 pm
Try with a test lamp and see where the power stops before you start pulling things apart.
"Let us remove your "SHORTS"
PostPosted: Fri Jul 20, 2012 4:18 pm
Dirty connections. Thanks drmini :)
Carpe Diem
1967 Deluxe (Bluey)
Users browsing this forum: Bing [Bot], Steam and 100 guests
