It is currently Tue Aug 05, 2025 9:49 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Aug 01, 2012 4:02 pm
The Mini King
simon k wrote:
John Smidt wrote:
I mentioned this type of arm to A customer the other week, and He explained to
Me that it was a figment of My imagination probably because of age
as he had never seen such a thing and never heard of them
I just wanted to check if others remembered them
so even someone like you who has been in the mini business forever and ever has "experts" trying to tell them their version of the truth?
far out....
I am always happy to listen to people because I do not belive that I know every thing
there is to know about Minis, However I try to make a point not to comment unless
I am sure of what I am talking about,
I have been around Minis for more than 2 thirds of My life And I think that
I have gathered a bit of Knoweledge about the Mini in that tme
and I am happy to share it with anyone who asks.
I must say that it is strange when people ask Me about something, and then want
argue the point
PostPosted: Wed Aug 01, 2012 6:52 pm
:roll:
Have a Nice Day.
PostPosted: Fri Aug 03, 2012 5:00 pm
850man wrote:
M1100, what is the number of the Tech Bulletin you have? I would like to find it in my set and read it.
How would I know, I'm just a dumb concrete truck driver.
PostPosted: Fri Aug 03, 2012 5:19 pm
Concrete truck driver?
I thought you drove trains, or is it someone else that's the engineer?
You're so square
Baby I don't care
PostPosted: Fri Aug 03, 2012 6:18 pm
I could only dream of having the wealth of knowledge of John Smidt, so my contribution to this discussion is limited to looking through various Mini parts catalogues. Of course these publications weren't always 100% accurate so don't blame the messenger if you disagree with what follows.
Apologies for the size of the images below but any smaller and you couldn't read them. If you'd like a better copy emailed to you just ask.
The first parts catalogue for Australian Minis was the UK produced AKD1153.
Page H1 shows the strut assembly as part 2A7375, with a Washer for strut (special) as 21A463 commencing at car 34099. Page H2 shows the radius arms as parts 2A7343 and 2A7356, with new parts 21A171 and 173 commencing at car 5488.
The first Australian produced parts catalogue for the Mini (Morris 850 and van) was HYL2980.
Page H2 shows strut assembly 2A7375 (steel) being replaced by 21A1031 (die cast). As well as the 21A463 washer mentioned above there appears another washer - special - strut (.100") part AJH5322 to be used as required. Service Bulletin C227 refers (see copy below).
Page H3 shows radius arms 21A171 and 173 as being no longer available and to use 21A392 and 393, commencing car 88818.
There's no mention of the type of construction of the radius arms.
PostPosted: Fri Aug 03, 2012 7:13 pm
This is the Service Bulletin that mentions a problem with the fabricated arms. I've just posted the first of six pages.
PostPosted: Fri Aug 03, 2012 7:25 pm
Mods rock!
Thanks Winabbey,
So from the parts listing, it would seem that the Trailing Arm Pivot Pin is the same that we have these days, but in the Tech Bulletin, there is a different Pin. Any Part numbers or listings on those with the two grease nipples? They'd break pretty easy.
PostPosted: Fri Aug 03, 2012 7:26 pm
re the last bulletin above,
Seems my memory ain't too bad after all. :wink:
PostPosted: Fri Aug 03, 2012 7:39 pm
I think I imagined it.
PostPosted: Fri Aug 03, 2012 9:09 pm
Does anyone have the tech bulletins relating to converting wet primary gears to dry? It would have been some time in 1962, I think.
Another one that would be handy would be about converting bronze cone synchro boxes to baulk ring.
Thanks
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Aug 03, 2012 9:11 pm
Here's the other five pages.
PostPosted: Sat Aug 04, 2012 11:16 am
Great stuff Winabbey,
Its good to see that the Tech bulletins are being used for there intended purpose, to educate all us BMC mechanics!
Your BMC collection and knowlage is second to none.
John Smidt wrote:
The information And knowledge You have is just fantastic.
Have a Nice Day.
PostPosted: Sat Aug 04, 2012 11:46 am
The Mini King
Thanks
Tim I know this is not what You asked about however
the synchro conversion kit is mentioned in the parts book PUB1056M
Part number 8G718/M Years ago I purchased about 60 of these Kits because
at the time You could not get baulk Rings
It is interesting to note That the 3Rd motion shaft ( Main shaft ) is smaller in Dia and has to be used with a smaller double row bearing
PostPosted: Sat Aug 04, 2012 2:26 pm
Thanks
I hope John doesn't mind us littering his thread with Service Bulletins...
PostPosted: Sat Aug 04, 2012 2:48 pm
My red BMC shop manual section H6 says:
"From car # MA2S4 34099 and AA2S7 44722 trim height was raised by fitting a washer between the suspension strut and the knuckle end.
Later vehicles with cast type struts do not require washers".
This bulletin covers similar ground...
Users browsing this forum: i got a mini and 91 guests
