It is currently Sun Aug 24, 2025 9:32 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 352, 353, 354, 355, 356, 357, 358 ... 568  Next
PostPosted: Sun Aug 19, 2012 8:12 pm
Mokesta wrote:
So a sad day really. Wife is p1ssed that I spent the day in the shed and I still don't have a car I can drive.
I can relate to that Mark. :?
Alec
PostPosted: Tue Aug 21, 2012 11:26 am
Last night I took the clutch slave out and gave it a good clean out. There were some deposits on the bore that came off with a wire brush and the cup looked fine so I re-assembled it and re-bled the system. It bled up fine without sucking air back in. Win.
I adjusted the return stop so that the clutch disengages with one pump of the pedal so I think I now have a functioning clutch. Win.
I took the Facet pump out and pulled it down. It looked perfect so I re-assembled it and put the filter after the pump instead of before. Disconnected the fuel line at the carby and ran the pump. She was a gusher so pump isn't the problem. Win.
Put a new dizzy cap and rotor in. It is a MG Metro A+ electronic dizzy.
Found the tacho wire dangling in the engine bay so I put that on the coil :oops:
It was 11:30pm when I finished so I didn't take it for a test-run and wake the wife, kids and neighbours.
If it still has a miss then it must be plugs, ignition wiring or the condensor. I have changed everything else out. Leads, cap, rotor, ignitor, coil, a kit through the carby, check fuel pump, new manifold gasket, rocker clearances right.
I'll find out tonight. Wish me luck.
M
PostPosted: Tue Aug 21, 2012 9:22 pm
Getting a tad anal towards the Mini Muster... :? :?
Green Single wire clips... I hate the bloody things... Its horrible to fit.
I can see why there are no longer used...
PostPosted: Tue Aug 21, 2012 9:59 pm
Took the Moke for a test drive with tool kit and extinguisher for company.
The clutch is working brilliantly.
Thanks to Matt Read for: lightened flywheel, balancing the fly and setting up the clutch, the rod change shifter alloy seal thing with the o-ring on the inside, the oversize primary thrust washer and also the engine mount rubbers (those orange ones). All these add up to a clutch that is light and doesn't slip, an engine that stays where it is, a car that accelerates smoothly and a gearbox that doesn't leak. Ripper.
Thanks to Covertible Mini for the alternator (which I got indirectly) it rocks. I now have bright headlights at idle. Woot, it's a first for my Moke.
I got about 200m down the road and the missfire was obvious so I pulled up and pulled off the wire to the condensor. Off we go and she is purring!
I got a bit carried away and went a bit far on my test drive. About 6 km from home I could smell fuel. Stopped under a street light and looked around. Saw that the fuel float pivot pin/screw in the float chamber of the HIF had come loose and was nearly out. Fuel pouring out and onto the subframe about 50mm from the exhaust!
I couldn't get it properly threaded and just lightly got it in but cross threaded. Tried to limp home but the needle valve must have been shut as she died at a set of lights about 4 km from home. Luckily there was nobody around and I could roll backwards into a driveway of some shops. The area was well it so I took the carby off the manifold, removed the float base and re-assembled the float and pin. The PITA was that the big o-ring style seal had grown about 10mm too large in diameter and simply wouldn't go back in its seat. Is that ethanol in the fuel or just the usual crap parts that are around these days? I managed to sort of get it to work and drive home.
The moke is safely home and I didn't have to use the extinguisher. Phew.
Moral of this story is to check and double check all fasteners.
So it looks like I'll have a car that can drive to the Muster. Finally.
M
PostPosted: Wed Aug 22, 2012 8:30 am
Gear stick snapped, found a dodgy weld at the base of it. Rang local & convenient mini repair shop (no names) and asked if I could buy a second hand gear stick (got the usual oh they are rare to find now and you will have to order a new one).
Rang Brian at link, sent wife, 90mins (85mins her round trip driving) later gear stick installed. Cost? Nothing, but you can be damn sure another two slabs of VB will be stuck in the engine bay next time it goes up and will need fixing/removal.
PostPosted: Wed Aug 22, 2012 3:01 pm
Pissed of those braided fuel lines.... and got normal black as per factory pipes. And surprise surprise they don't leak.
PostPosted: Wed Aug 22, 2012 4:26 pm
Got some seats delivered I ordered last week .
PostPosted: Wed Aug 22, 2012 8:36 pm
12 months fly by when you're having fun - rego papers arrived the other day so off for a pink slip this arvo
the Mini Matic failed on needing two tyres (and have already them replaced now) and an oil leak that needs attention (I knew that was coming!) but is booked in for a fix up next week
can't believe I've had this Mini back on the road a year already
PostPosted: Wed Aug 22, 2012 10:44 pm
Seats look great!! Newton Commercial?
PostPosted: Wed Aug 22, 2012 11:07 pm
Prepping old set of S calipers for painting - spent a good couple of hours scraping dirt and grime off one caliper this arvo. Weapons of choice were flat-bladed paint scraper, pointed scratch awl, green scourer pad, wire brush, toothbrush, a nail and a pop rivet.
Messy, repetitive, but tremendously satisfying.
the internet wrote:
Like Audrey Hepburn, almost everybody loves the Mini. The only people who didn't love the Mini were pathetic, empty people.
PostPosted: Thu Aug 23, 2012 7:09 am
Seats are just classic cobras from revelation art race gear in qld
PostPosted: Fri Aug 24, 2012 6:39 pm
Pulled everything off the front of my motor. Bought another engine and teams from eBay. Advertised as a 1000 but by my research it's a 1100 so if that's right then I have my start block for our clubby.
Stripped and painted the headlight bowls and cleaned up all the little bolt ons for engine mounts and painted them too. Once the weather clears up I'm going to pull the engine and trans and front sub frame.
Got accused by my wife of having miniitis, an unwilling ability to buy anything and everything mini that takes my attention..omg she's right..
If its got tits or wheels its gonna cost you
1973 Solid side Leyland Mini Panelvan 1100 in Hairy Lime(Elma)
1976 Clubby project in progress
1966 Morris Mini Deluxe in need of a full resto
1971 Mini K Garden Art
PostPosted: Fri Aug 24, 2012 8:23 pm
Wrapped my extractors. All the pieces are lying in wait on my bench for the block to come back. Gotta get it all done before rego fully lapses in 6 weeks.
PostPosted: Fri Aug 24, 2012 8:36 pm
spent the day browsing minisport thinking about what I might treat the mini to if i get made redundant next week, I'll be damn upset if I don't :) I've already bought those brakes in my mind :)
Basil - 1978 Leyland Mini, Brooklands Green, bit of a bitsa, and a park brick in the boot. :)
PostPosted: Sat Aug 25, 2012 4:44 pm
Took it for a drive to my brothers 10th birthday slot car racing party. Was great to see the shopowners collection of slot car minis and the look on the kids faces when we drove out of the carpark. I guess most of them had no idea about "real" minis :)
Users browsing this forum: s-c1293 and 297 guests
