adamstuart wrote:
Nicho wrote:
Should i have it soda blasted before hand to make it ready
If you take something to a powdercoater they will say whether it's too dirty or not.
So most likely, yes you should blast it first.
Don't forget about the bearings and seals, they will need replacing
yep defenatly take the bearings out first ..
my coater is also a sand blaster so it was very easy .. just be carefull of what they call out gassing which will cause little bubbles in the coating .. make sure its cleaned of all oil and dirt or it will happen
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
