It is currently Sun Aug 24, 2025 4:00 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 355, 356, 357, 358, 359, 360, 361 ... 568  Next
PostPosted: Sun Sep 02, 2012 10:12 pm
The wife said I played with it too long cause I finally pulled the head off it.
Ok now I got your attention I pulled the 12g202 head off cleaned it up. Ready to send it off for porting and polishing and new valves etc..
Found out my extractors are beyond the thunder dome, so looks like I need a new set.
By the end of the week ill have a running 998 with new clutch and all accessories up for sale.(that's not what the heads for)
So for fathers day it was very productive
Now the weather is being a bit nicer in Vic I'll be able to pull the front subframe and get the motor ready for machining. The project continues. The sound of a mini engine will be heard in the not too distant future burbling from my garage..
If its got tits or wheels its gonna cost you
1973 Solid side Leyland Mini Panelvan 1100 in Hairy Lime(Elma)
1976 Clubby project in progress
1966 Morris Mini Deluxe in need of a full resto
1971 Mini K Garden Art
PostPosted: Sun Sep 02, 2012 10:26 pm
Done the body work!!
Painting soon hopefully :D
1978 Leyland Clubman
PostPosted: Sun Sep 02, 2012 10:28 pm
Wow it's almost the same color before I'm guessing.. What color are you going now?
PostPosted: Sun Sep 02, 2012 11:06 pm
Keeping it Jade Green :)
PostPosted: Sun Sep 02, 2012 11:13 pm
Nice. I'm building mine for my wife who wants dove egg blue but the original color was baby s$)t brown so anything has to be better
PostPosted: Tue Sep 04, 2012 10:38 am
Woot, old style sandcast rocket cover arrived, might duck down to peps at lunch and get some wrinkle paint for it :)
Basil - 1978 Leyland Mini, Brooklands Green, bit of a bitsa, and a park brick in the boot. :)
PostPosted: Tue Sep 04, 2012 9:43 pm
Fitted the final bits for the Muster and Restoration......... But its a surprise, for those at Muster to see! :P
PostPosted: Thu Sep 06, 2012 7:00 pm
Re-installed the started motor.
Adjusted the wipers some more - they now work.
Tightened some loose bolts.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Thu Sep 06, 2012 8:01 pm
I looked at it after 24 hrs work in 36 hours.. Does that count.. Damn wind and railway lines dont mix
PostPosted: Thu Sep 06, 2012 8:36 pm
Used my brand new flywheel puller and separated the 4 syncro gear box from an old 1100 engine.
PostPosted: Sat Sep 08, 2012 2:31 pm
Got 4 new tyres for the moke and went to Clark Rubber and got enough matching rubber flooring to cover the tray area and floor behind the front seats. The new stuff is identical to the 30 year old floor matting in the front that the car came with!
I also adjusted the tappets and leaned out the mixture screw as the plugs were black. I may have to change needle but I'll put the oxygen sensor on and measure how this one is going one day.
It's too hot to wash it now, I'll do that this afternoon in preparation for the Muster.
PostPosted: Sat Sep 08, 2012 6:19 pm
took if for the annual rego inspection
PostPosted: Sat Sep 08, 2012 6:46 pm
Bought it home from the spray painters woo hoo thanks to Aussie Brian for his invaluable help , now starts the reassembly program.
PostPosted: Sat Sep 08, 2012 7:09 pm
Oil change and indicator cam adj properly for new indicator switch.
Now with 2 extra ports!
PostPosted: Sat Sep 08, 2012 8:04 pm
Started to take apart my transmission.
Send of my block to get bored out.
Glad to see my mini is finally making some progress. Cant wait to drive it
Users browsing this forum: No registered users and 182 guests
