It is currently Thu Aug 14, 2025 6:53 pm
PostPosted: Sat Sep 08, 2012 10:06 pm
Am thinking of swapping gboxes on my engine.
Currently run an A+ box with 3.1 diff.
Not happy with gear ratios, in particular 1st & 2nd, and want to swap to a 3.44 diff.
I have a 4 synchro remote box with 3.44 dif. Would like to convert it to cooper s cr gear ratios and use it.
So what's involved with putting it in a clubby?
Rear remote housing bracket
Do I need to swap driveshafts to accommodate the steel Uni joints?
Anything else?
Thanks.
Now with 2 extra ports!
PostPosted: Sun Sep 09, 2012 9:36 am
You can run pot joints if you want. I just changed to pots in mine.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sun Sep 09, 2012 9:41 am
depending on what year shell, you may also have to modify the hole in the floor slightly, to mount the rod change mechanism.
PostPosted: Sun Sep 09, 2012 9:44 am
I think he's wanting to go the other way - Rod change to Remote.
Dicko.
PostPosted: Sun Sep 09, 2012 4:41 pm
Yes rod change ATM, switch to Remote in a 78 clubby Van.
PostPosted: Sun Sep 09, 2012 10:15 pm
You need a gearbox, the shift mechinism, remote gearstick and a bracket from a hydro car
PostPosted: Mon Sep 10, 2012 7:44 am
Dicko.
Typo - thanks Dicko.
I say that as the floor in my '71 clubman had to be modified to fit a rod change. Maybe the very early ones came out with remote?
And yes, there was a typo in my original response, I meant mount a remote.
Users browsing this forum: Bill B and 230 guests
