It is currently Sat Aug 09, 2025 3:24 am
 Post subject: Car ID?
PostPosted: Sun Sep 16, 2012 1:28 am
Can anyone ID this from the compliance plate?
Mini 022 A2S2 M10 544
Date: 3/73
Thanks!
Now with 2 extra ports!
PostPosted: Sun Sep 16, 2012 8:04 am
High heel ninja
Should be a clubman, 1100cc engine.
Doogie
PostPosted: Sun Sep 16, 2012 9:59 am
A very early Leyland Mini S. The 44th one made.
PostPosted: Sun Sep 16, 2012 10:06 am
Thanks, so just a clubman. Would a clubman S be indicated on the comp plate or is it only identified by badging? Cheers.
PostPosted: Sun Sep 16, 2012 12:10 pm
Be thankful you have a Clubman.. I only have a Leyland mini :?
 Post subject: ID Plate
PostPosted: Sun Sep 16, 2012 4:41 pm
By your ID plate the car is a Leyland Mini S where
022 - Leyland Mini S
A - Leyland Mini or Van in manual trim
2S - 2 door sedan
2 - Medium trim level ie Mini S
M10 - 1098 cc engine
544 - Build number which started at 501 which means your car is number 44 off the production line. The vehicle name changed from Morris Mini Clubman body index 021A2S2M10 to Leyland Mini S body code 022A2S2M10 on 1 March 1973 to comply with British Leyland requirements for all vehicles to bear the Leyland name and the dropping of all other names such as Morris.
I have been researching this infromation for all Oz built Minis and will be publishing the same very shortly.
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
