It is currently Sat Jul 19, 2025 7:57 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Thu Sep 20, 2012 11:18 am
The Mini King
The original clip for holding the flare and the chrome Trim is MYH45 We have these new old stock
PostPosted: Fri Sep 21, 2012 6:29 pm
I decided to try and straighten out the trim before fitting so I put it on the clothes line , yep on the hills hoist , opened it up and fed it onto the wire and left it out in the sun for the day , not bad better than out of the packet.
PostPosted: Sat Sep 22, 2012 5:21 pm
Got the trim on one side was good and the other side not so good . The side that is good I used the upside down method so it bent naturally when it went around the bottom curve , you have to get your fingers into it and open it up then it is a little difficult to feed it over the wheel arches but it nearly holds it self on . It is not perfect but it is pretty good and together with a little super glue It doesn't look too bad. Thanks for all the tips , remember this is non S trim.
Users browsing this forum: No registered users and 69 guests
