It is currently Sun Jul 20, 2025 12:26 pm
 Post subject: Indicator issue
PostPosted: Sat Sep 22, 2012 5:49 pm
My hazards work but my indicator stalk seems to
Be dropping in and out? When turning left or right
Finally now nothing.
I sprayed a heap of contact
Cleaner in there incase and it made the click sound once
To the flasher then nothing.
hazzards work dash lights work
Any ideas? Is there a contact that wears inside the stalk?
it's a rover stalk.maybe i m up for a new one?
PostPosted: Sat Sep 22, 2012 7:45 pm
Could be your flasher can (relay). They usually use a different one for indicators and hazards as the current draw is different. In saying that the 2 relays could be in the one housing.
Dicko.
PostPosted: Mon Sep 24, 2012 8:32 am
As Dicko says, in a Rover there are two flasher cans, one for the hazards and a separate one for the indicators.
Before you ditch the indicator control arm, also check out the hazard switch - the indicator wiring goes from the control arm on the column to the hazard switch then off to the lights. The hazard switch is a double poll double throw that in the "on" position connects the hazard circuit to the lights but in the "off" position connects each indicator circuit to the lights.
