It is currently Sun Jul 20, 2025 12:15 pm
 Post subject: Indicator issue
PostPosted: Sat Sep 22, 2012 5:49 pm
My hazards work but my indicator stalk seems to
Be dropping in and out? When turning left or right
Finally now nothing.
I sprayed a heap of contact
Cleaner in there incase and it made the click sound once
To the flasher then nothing.
hazzards work dash lights work
Any ideas? Is there a contact that wears inside the stalk?
it's a rover stalk.maybe i m up for a new one?
PostPosted: Sat Sep 22, 2012 7:45 pm
Could be your flasher can (relay). They usually use a different one for indicators and hazards as the current draw is different. In saying that the 2 relays could be in the one housing.
Dicko.
PostPosted: Mon Sep 24, 2012 8:32 am
As Dicko says, in a Rover there are two flasher cans, one for the hazards and a separate one for the indicators.
Before you ditch the indicator control arm, also check out the hazard switch - the indicator wiring goes from the control arm on the column to the hazard switch then off to the lights. The hazard switch is a double poll double throw that in the "on" position connects the hazard circuit to the lights but in the "off" position connects each indicator circuit to the lights.
Users browsing this forum: No registered users and 72 guests
